DynoTime for the 461 ..
Old Feb 26, 2004 | 03:33 PM
BB wowbagger's Avatar
BB wowbagger
Default DynoTime for the 461 ..
Going to Dyno my newly built 461 tomorrow and thought i`d start a little guessing game on the output on the engine.
The engine i built with this:
.030 bored 454 block
Ported 781 Ovals with 2.19/1.88 valves.
11:1 TRW slugs.
Fully balanced.
Comp Mech roller 288 AR (11-692-8).
Edelbrock RPM intake.
Holley 950 HP Carb.
Will probably spinn it to 6200.
So,what will the numbers be?
:cheers: :cheers:
Old Feb 26, 2004 | 04:16 PM
Corvette_fetish's Avatar
Corvette_fetish
Default Re: DynoTime for the 461 .. (BB wowbagger)
I'm curious to see what it produces. My mechanic has two big blocks. One is going in his '80, the other is a 461 he had in a truck. He wants to sell it to me for my '79. He said it makes like 600+ hp, so 650hp is my guess.
Old Feb 26, 2004 | 04:38 PM
Corey_68's Avatar
Corey_68
On the motor dyno or at the rear wheels?
My guess is 550hp Flywheel Hp, hope I'm wrong though we have somewhat similar setups. :D
What are the specs on the 288 cam?
Should be impressive numbers without a doubt. :thumbs:
Old Feb 26, 2004 | 04:49 PM
BB wowbagger
Default Re: DynoTime for the 461 .. (Corey 68)
Its just for the engine alone... :cheers:
Old Feb 26, 2004 | 05:37 PM
Doug Brandon's Avatar
Doug Brandon
Very interested in your results too. 427Hotrod has raved about that cam. I am thinking of using it for a 460 build-up. I would guess 540 hp, 575 ftlbs torque. The heads might be the limiting factor-depending on your port work, of course.
Old Feb 26, 2004 | 06:03 PM
Glenn454's Avatar
Glenn454
560+hp/560tq Let us know what It makes, sounds like a good combo.
Old Feb 26, 2004 | 10:27 PM
ZL1powr's Avatar
ZL1powr
If the heads flow good it should produce nearly 600 HP at the fly wheel. That is the same cam I am using and I have been very happy with it.
Old Feb 27, 2004 | 12:48 PM
BB wowbagger
Default Re: DynoTime for the 461 .. (ZL1powr)
And the numbers are in.. :cheers: :cheers:
610Hp @ 5471 Rpm
634.8Ft/lbs @ 4578 Rpm
This was my first Dynorun,and the noise was incredible. :cheers:
Old Feb 27, 2004 | 12:52 PM
Fevre's Avatar
Fevre
Is that all? :jester
Nice numbers! :thumbs:
Old Feb 27, 2004 | 12:53 PM
BB wowbagger
Default Re: DynoTime for the 461 .. (Fevre)
:lolg: :cheers: :thumbs:
Old Feb 27, 2004 | 02:00 PM
Corey_68's Avatar
Corey_68
Sweet numbers :thumbs: What are the specs on the 288 cam?
Also what the % of parasitic loss once you bolt the accessoies (water pump, alternator, PS pump, A/C?) vs what just the engine made?
Congrats :cheers:
Old Feb 27, 2004 | 02:31 PM
Glenn454's Avatar
Glenn454
Impressive :thumbs:
Old Feb 27, 2004 | 02:32 PM
BB wowbagger
Congrats :cheers:
http://www.compcams.com/Technical/Se...umber=11-692-8
About the parasitic loss,i have no idea.. :smash: :cheers:
Old Feb 27, 2004 | 02:37 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
550 HP!!
Old Feb 27, 2004 | 03:12 PM
Brettmc's Avatar
Brettmc
Those numbers peaked real low. I bet that's gonna be a blast to drive on the street. One question: Since it peaked so low, do you think you could have the same performance from a hydraulic roller? Or even a hyd flat tappet?
Brett
Old Feb 27, 2004 | 03:16 PM
Fevre's Avatar
Fevre
Default Re: DynoTime for the 461 .. (Brettmc)
Brett
Brett
I thought the same thing, peaking at under 6000 rpm's there is not much chance of lifter float if using a hyd roller.
Old Feb 27, 2004 | 03:49 PM
PatsLs1vette's Avatar
PatsLs1vette
very impressive numbers :cheers:
To DynoTime for the 461 ..
Old Feb 27, 2004 | 04:02 PM
BB wowbagger
Default Re: DynoTime for the 461 .. (patsnitrovette)
I wonder how my Muncie will react to those numbers.. :smash: :lol:
Old Feb 27, 2004 | 04:59 PM
big632's Avatar
big632
Your oval heads will give it great torque but kill hp above 5500 rpm.switching to rectangle heads will bump up the power band and higher hp . even torque will be increased with that rpm manifold.nonetheless it should be a blast to spin tires off the car.
Old Feb 27, 2004 | 05:18 PM
Glenn454's Avatar
Glenn454
BB wowbagger, Your muncie should be fine as long as It's In good shape. I ran my muncie behind a 450 rwhp BB and 500+rwhp on nitrous. Unless your pulling the tires when you launch at the track,your muncie should hold up. Your clutch Is going to hate you. :)
