Water pump valve?
Old Feb 26, 2004 | 05:25 PM
Vette-4-Life's Avatar
Vette-4-Life
Default Water pump valve?
Looking thru my haynes manual i can not find a reference to the following:
Between the water pump and the heater core there is something (valve?) mounted to the passenger wheel well. It appears to be a pass thru device as a hose from the water pump goes in the top and a hose to the heater core goes in the bottom. It also has what appears to be a vacuum line coming out of the top of it and running back into the firewall. This has developed a leak and i would like to by pass it with a new/longer section of hose and connect the water pump directly to the heater core.
Any reason not to bypass?
This is for a 1980
Old Feb 26, 2004 | 05:30 PM
Fevre's Avatar
Fevre
Default Re: Water pump valve? (Vette-4-Life)
That is a shut off valve that stops hot fluid from going into the heate core when you a/c is on, some people use a manual one for the summer so their a/c works more effeciently or to just keep it cooler in the passenger compartment if they do not have a/c. No problems bypassing since that is the way it is on non a/c cars.
Old Feb 26, 2004 | 05:48 PM
Vette-4-Life
Thanks, AC doesn't work so for now i will bypass.
Old Feb 26, 2004 | 06:40 PM
Yeller81USNRet's Avatar
Yeller81USNRet
Put in a Manual shut off valve if possible or it will warm things up in the Cockpit.
Don't ask how I know this .
:steering:
To Water pump valve?
