Fuel Filters
Old Feb 27, 2004 | 11:54 AM
jamesx0's Avatar
jamesx0
Default Fuel Filters
I need to get a fuel filter for my new fuel line from the mech pump to the carb. What is the difference between the screen type and the sintered bronze?
Old Feb 27, 2004 | 03:51 PM
jamesx0's Avatar
jamesx0
Default Re: Fuel Filters (jamesx0)
ttt
Old Feb 27, 2004 | 04:02 PM
PRNDL's Avatar
PRNDL
I am a little confused. Is the "sintered bronze" the description used for the little in-the-carb filter that goes in the fuel inlet? There are 2 types, one paper, and one metal. If you' re really talking about inline fuel filters I dont know what a "screen type" filter is. You can use a generic fuel filter that splices into the fuel line with rubber hose connections or you can build a fuel line like I did that accepts a screw-on type filter. I would stay away from the glass inline fuel filters. MJ
hold on.... I see from your sig you have a 68. (so do I) What kind of fuel line did you get? Is your fuel return line intact? If it is all stock you have to get a gf432 fuel filter. For in the carb you should also have a little paper filter. Before I go into great detail give us a better idea of what you have, ie stock replacement fuel line or aftermarket. MJ
[Modified by MNJack, 4:05 PM 2/27/2004]
Old Feb 27, 2004 | 07:44 PM
jamesx0's Avatar
jamesx0
Default Re: Fuel Filters (MNJack)
I am looking at fuel filters for AN lines. The two Earl's -6AN fittings are http://store.summitracing.com/partde...t=EAR%2D230106 for the sintered bronze, and http://store.summitracing.com/partde...t=EAR%2D230206 for the screen type. Both of these filters have an aluminum housing and both of the filtering media are cleanable. I was wondering what the pros and cons to each were.
To Fuel Filters
