Stretched Parking Brake Cable?
Old Mar 16, 2005 | 04:46 PM
kenko74's Avatar
kenko74
Turns out I was missing the steel spacer/bushing insert in the white plastic parking brake pulley. Without the spacer, the pulley was pulled back from off center, causing just enough slack to prevent proper cable tension adjustment. Problem solved.
