help!!! lights open after engine is turned off?
Old Feb 27, 2004 | 09:56 PM
BEZ71's Avatar
BEZ71
Default help!!! lights open after engine is turned off?
just replaced all hoses and now the lights open when i turn car off. i can here vacume leaking but just can't ppinpoint location.
Old Feb 28, 2004 | 12:22 PM
Tom Johnson's Avatar
Tom Johnson
Default Re: help!!! lights open after engine is turned off? (BEZ71)
Sounds like your check valve. It says in the Dr. Rebuild catalog that a leaky valve will cause the head lamp or wiper doors to pop open when you shut off the engine. If thats your problem I would replace the vacuum filter also.
