Parking Brake Adjustment Tip
Old Feb 28, 2004 | 09:54 AM
kenko74's Avatar
kenko74
Default Parking Brake Adjustment Tip
For those of us finishing our winter projects and installing rebuilt T-arms, I have a good tip to pass on in reference to adjusting Parking Brakes: Adjust your parking brakes before hooking up your half shafts. Use a jack stand or rope to hold your T-arm at normal riding height, and with the front bolt and enough shims in place to keep from wobbling, attach the parking brake cable to both T-arms and then adjust your parking brake shoes. With no resistance from the driveline, the rear rotors are easy to turn and you know exactly when the shoes are engaged/disengaged. :cheers:
