72 vette vacuum whoa's
Performer RPM intake (7101) and cam (7102 hydraulic)
kit and now have trouble with vacuum. I currently am
using the stock distributor and stock vacuum advance,
in order to get the car to idle/run properly with the
car in gear (500-600rpm), it has to idle at 16-1800
rpm while in park.
With the vacuum advance hooked up and the car running
when you remove the line there is verry little change
in the way the motor runs. I have had the vacuum
advance checked and it is fine. At idle i am getting
very little vacuum pressure thus the car labors while
at idle in park and in gear, however when given some
gas the vacuum advance kicks in advancing the timing
to about 22 degrees and there is 18" of vacuum however
the car idles at 1800rpm standing still and 600rpm
while in gear. The engine performs very well while
driving however when idling the motor is racing. When
the carb (edelbrock 1405) and timing are adjusted to
counter act the problem it idles poorly and
performance is hindered until the engine gets gas and the rpm's
are increased at which time it works as it is supposed
to however once the rpms return to normal the engine
labors, vacuum seems to bleed down and there is very
little vacuum pressure. Not sure, is there a vacuum advance that you can buy that is adjustable as to the pressure required to open the diaphram? I'm open to suggestions/solutions anyone can provide!
:crazy:
:chevy
Sounds like you have something else going on unrelated to the cvacuum advance...
Please check and double check for a vacuum leak. That cam is NOT that radical. It should not cause the issues you describe.
You can use the spray carb cleaner trick. Spray it around the base of the carb, fitting, etc with the engine running to see if the idle speed changes (indicating a vacuum leak).
If you have NO vac. advance at idle, which I believe is correct for our years, you are hooked up to ported vacuum.
Good luck, and let us know what you find :cheers:
of not that, you most assuredly have an open vacuum port on there somewhere....listen for the sucking sound using a hose to your ear....
GENE
