Dissapointing Dyno run
Old Mar 1, 2004 | 03:45 AM
Jay M's Avatar
Jay M
Default Re: Dissapointing Dyno run (MNJack)
According to the Dynomax website the Flowmasters are killing me!
IT sys that HP x 2.2 = CFM needed
490 HP x 2.2 = 1078 CFM needed
For Dual exhaust I would need a Muffler capible of 539 CFM each, the Flowmasters are only 362 cfm.
Maybe I can redeem a significant amount of HP!! Headers plus Better mufflers :)
~Jay
Old Mar 1, 2004 | 03:51 AM
Shark Racer's Avatar
Shark Racer
Default Re: Dissapointing Dyno run (Jay M)
Jay- The Ultra Flos should be quieter than the Flowmaster 50s and PERFORM the way you need them to! I think they are an awesome sounding muffler as well.
-Steve
Old Mar 1, 2004 | 10:42 AM
groovyjay's Avatar
groovyjay
Here's one alternative if you are looking to replace the stock iron manifolds:
http://www.sandersonheaders.com/page...num/qp2000.htm
Old Mar 1, 2004 | 12:04 PM
Jay M's Avatar
Jay M
Default Re: Dissapointing Dyno run (groovyjay)
Those are very interesting! But are they worth the expense and do they work as well as normal headers?
I saw something else on the Sanders websight that was very interesting. They have a chart showing recommended pipe size per HP and ci displacement. http://www.sandersonheaders.com/completeperftech2.htm
According to that I need 3" exhaust.
Do you think this is true? The expense and noise of 3" exhaust might be a problem. But I didn't pay $7000 for a 300hp engine! Will a 3" exhaust fit through the cross member?
Thanks,
~Jay
~Jay
Old Mar 1, 2004 | 03:42 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
3" will fit through crossmember if you have a good muffler guy. Mine is fine and doesn't rattle at all.
The 2.5" is far from optimum, but it isn't killing you too bad. I was running lo-11's@123 mph in my '67 capped up through 2.5" pipes all the way out the back. Uncapping it made little difference at the track. This was with a 6500+ rpm 427 making 423 RWHP.
The Dynomax's are good mufflers. I didn't have much resonance issue with the 40 series, but as airflow requirements got heavy, they couldn't handle it. The ultrflows are great too.
JIM
Old Mar 1, 2004 | 05:26 PM
Jay M's Avatar
Jay M
Default Re: Dissapointing Dyno run (427Hotrod)
Ok,
as usual you guys have helped me tremendously and cost me a small fortune!!
My current plan-
add Headers
replace 2.5" exhaust with 3" exhaust
Replace Flowmasters with Something better- probably Dynomax
Then take the car to a shop an hour away that does carb tuning on a chassis dyno to fine tune it.
I own the headers already, but they may need to be modified
Mandrel bent 3" exhaust including header installation and mufflers I'm guessing $1200
Dyno tune maybe $300?
So $1500 for hopefully 80 rwhp isn't a bad deal.
~Jay
Old Mar 1, 2004 | 10:27 PM
Jay M's Avatar
Jay M
I got a quote from the muffler shop. He says it will be under $1000 to install the headers, 3" exhaust with H pipe, and Borla Mufflers. Other mufflers would be slightly cheaper.
I'm keeping my fingers crossed that he won't have any problems with the headers.
Hopfully he can get to it this week :) If so, I'll post new dyno results this weekend.
~Jay
Old Mar 2, 2004 | 04:00 AM
Shark Racer
That's a damn good price for all that PLUS Borla mufflers. I do not think you will be disappointed! Should feel almost like a cam swap.
-Steve
Old Mar 2, 2004 | 09:36 AM
Jay M's Avatar
Jay M
Default Re: Dissapointing Dyno run (Pacin'California)
-Steve
I sure hope so! But all bets are off if the headers don't fit properly.
~Jay
Old Mar 10, 2004 | 03:20 AM
Ironcross's Avatar
Ironcross
If your running a hydraulic cam, you got about as much as your going to get. If you want power over 6000 RPMs and to pull to 7000+ it will require a solid lifter camshaft and a good set of valve springs. Also, a 3/8`s fuel line is quite adequate to handle the engine. Thats all that is necessary for the L88`s and ZL1`s, including the 454 LS7`s that produce an honest 550+ HP tuned correctly.
