Paint problem
Old Feb 29, 2004 | 12:31 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Default Paint problem
Hi,
My fresh Paint job has developed a bubble the size of my thumb...:mad :mad
its on the passenger side just about a foot back from the rear of the door, right on top....I paid good money for my black base coat/clear coat finish...I don`t want to bring it back since it was a major pain with the painter...4 1/2 months and now he is going through divorce problems and getting his house and shop foreclosed on.
whats the best way to fix it...can I sand it and dab some clear on it...resand and buff? or is it in need of a complete resand and clear the entire rear end of the car?
any comments would be appreciated
Old Feb 29, 2004 | 12:34 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Paint problem (12stepvette)
it can be repaired without painting the whole panel, but best left to someone who has done it before.
performing spot repairs can be much more difficult than painting the car from scratch.
Old Feb 29, 2004 | 10:44 AM
69vette66's Avatar
69vette66
The first thing to do is determine why it bubbled? Was it repaired there? What kind of primer and paint was it? Did he Bake the paint? You have to find out why it bubbled before the fix can be made. The best way is to repaint the whole back have. That would be the right way to do. If ya just touched it up, might cause some problems do the road.
Good Luck :cheers: Larry
Old Feb 29, 2004 | 12:02 PM
turtlevette
Default Re: Paint problem (69vette66)
Well if you're gonna repaint the whole back half, you might as well repaint the whole car. For one small bubble in the paint? Geeze Louise.
Old Feb 29, 2004 | 03:21 PM
motown 71's Avatar
motown 71
Default Re: Paint problem (turtlevette)
Base coat / clear coat is the easiest paint to repair.
Was the car stripped down to bare glass ? Not knowing what year your vette is Could be the lacquer under your new paint causing the problem.
Anyway, the beauty of clear coat is you can wet sand the repaired paint and buff, if it is filled properly you'll never see it.
Good luck
Old Feb 29, 2004 | 03:44 PM
12stepvette
Thanks for all the replys!!
This has been a 4 1/2 month ordeal for me and I`m going to cut my losses with this arrogant butt!!!
The car is a `74 and no it wasnt taken down to glass or baked when the paint was applied...It sat in the full sun yesturday for the first time and it has developed other areas of concern...most of his repairs have lifted and other bubbles have also shown up...it has been hand sanded and the first cut with compound has been applied...I have given him till friday to finish the polishing...if its not done I will be taking the car home and buffing it my self.
I will be using a waffle buffing wheel and purchasing the correct polishes from Dupont...I figure I cant screw it up any worse!!!
I`m furious,totally disgusted and my stress levels can`t be healthy.
again, thanks for your support!
-la-
Old Feb 29, 2004 | 03:57 PM
turtlevette
you might want to consider an adhesion promoter in the problem areas. Its clear so it blends well.
Old Feb 29, 2004 | 04:40 PM
big632's Avatar
big632
Without taking a car down to gelcoat you have a can of worms.That is really the only way to go with a vette.Sounds like moisture trapped inside bubbling to escape in the heat.Painting a car has to be as clean as a surgery room. At least as clean as possible. There are steps to follow and many things can go wrong if they arent adhered too. Its all prep, painting is the easy part.Sorry for your misfortune.No one should have painted that car without stripping it down. especially black.I dont know what you paid,but if it was anything over 4000 it should have been done right. I know mine won best paint at world of wheels and it is black and I painted it. Materials alone on a quality paint job alone can cost 1500 and go to the moon for labor.Depending on what you have paid I would get money back .No polishing is going to fix paint bubbles.
Old Feb 29, 2004 | 05:34 PM
black77's Avatar
black77
Default Re: Paint problem (big632)
sorry to here about your misfortune!! this happens alot with the older vettes if you dont take the necesary steps the gel coat starts to get old & rotten & develop small pin holes not seen by the eye anyways you paint or prime over them & trap moisture are just air in them !!! the worst part about it if you leave it out in the sun more will pop up now without seeing your car its hard to be sure thats what it is but ive seen it happen a few times with shops not experienced with the older vettes. before you do anything to it let it sit out in the sun a few days if more come up thats probably what happened
Old Feb 29, 2004 | 07:06 PM
lbell101's Avatar
lbell101
Default Re: Paint problem (black77)
People, please quit spreading ther Gelcoat myth. Our cars never had a gelcoat from the factory.
Sorry to say it but these guys are right. Sounds like very poor prep work.
Larry
Old Feb 29, 2004 | 07:16 PM
big632's Avatar
big632
Default Re: Paint problem (lbell101)
ibell some use the word gelcoat instead of factory primer.Whatever floats your boat.
Old Feb 29, 2004 | 07:23 PM
lbell101's Avatar
lbell101
Sorry, it's not the same thing.
Larry
Old Feb 29, 2004 | 10:18 PM
12stepvette
Just to let you guys know...I paid 5K to this guy who came well recommended and has alot of corvette experience...unfortunately his screwed up life got in my way!!!
I dont know what to do about it since I cant take him to court and I dont have another hard earned 5K to throw at the car :banghead: :banghead:
Old Mar 1, 2004 | 05:48 AM
big632's Avatar
big632
Thats a lot of money.I feel your pain. Maybe you can post some pics of the areas in need of repair. might be easier to repair than diagnosed.need to see to know what has to be done
Old Mar 1, 2004 | 10:08 AM
vetteboy1976kr's Avatar
vetteboy1976kr
:iagree: Post a few pics of the problem areas and these guys will help you out. Plus the advice is free!
To Paint problem
