427V8 -- Wilwood brakes
Old Mar 1, 2004 | 09:10 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default 427V8 -- Wilwood brakes
I can probably get the hard lines fabricated by my mechanic. Not to worried about that.
But the an lines. you are saying that the -3 an line will do the job?
Do I need to have these made or is there an off the shelf hose that I can use?
Possibly a stainless steel one?
I am looking for a tube with a 1/8-27 NPT for the caliper end and what kind of fitting on the other end?
Old Mar 1, 2004 | 09:25 AM
Guru_4_hire
Cruise-In V Veteran
Default Re: 427V8 -- Wilwood brakes (Guru_4_hire)
Would the 2 foot competition brakelines down at the bottom of this page do the trick
http://www.jegs.com/cgi-bin/ncommerc...84&prmenbr=361
with the adapters on this page
http://www.jegs.com/cgi-bin/ncommerc...18&prmenbr=361
Old Mar 1, 2004 | 12:27 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
-3 is a good size to use.
But make sure it's brake line not fuel line haha
I'll look at the links tonight, can't ( or shouldn't) from here
I'll also post a list of part numbers etc
Old Mar 1, 2004 | 12:43 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: 427V8 -- Wilwood brakes (427V8)
Sweet.
I am looking at the Superlite SL4 1.88/1.75 piston calipers and dynalite 1.75 calipers
fronts http://www.wilwood.com/products/cali...4lug/index.asp
rears http://www.wilwood.com/products/calipers/bdc/index.asp
that is an area of 5.18 for the front and 4.8 for the rear
or a ratio of .93 as close to stock as I can find
Do I want front side or rear side calipers?
[Modified by Guru_4_hire, 12:55 PM 3/1/2004]
[Modified by Guru_4_hire, 1:00 PM 3/1/2004]
Old Mar 1, 2004 | 09:16 PM
427V8's Avatar
427V8
The front calipers mount on the front, the rears on the rear...
A word of warning. These calipers stick out past the front of the hub by 3/4"
They are also bigger in diameter than stock. so they won't work with stock wheels and you'd better be sure they will fit!
Might want to look into the narrow body versions, more clearance.
Here are part numbers for braided AN line.
the rear flex lines go from the trailing arm to the Caliper. The don't flex in operation but only when bleeding since it is necessary to unbolt and rotate the caliper so the blead screws point up ( else air gets trapped inside)
[Modified by 427V8, 8:17 PM 3/1/2004]
Old Mar 1, 2004 | 09:19 PM
427V8's Avatar
427V8
Oh and don't be afraid to call Wilwood, they have an excellent support group.
805 388-1188
Old Mar 1, 2004 | 11:40 PM
rgregory's Avatar
rgregory
Do a search for Paragon Performance. I had them make me a set of 4 brake lines for my C5 to the length I wanted with the exact fittings I wanted for $100 and they were DOT approved.
Old Mar 2, 2004 | 01:34 AM
Corz's Avatar
Corz
Default Re: 427V8 -- Wilwood brakes (rgregory)
wait I'm lost.. what calipers fit the C3 ?
Old Mar 2, 2004 | 05:45 AM
Twin_Turbo's Avatar
Twin_Turbo
805 388-1188
:iagree: I found them very helpful too
Old Mar 2, 2004 | 06:54 AM
427V8's Avatar
427V8
Which is probably cheaper ( and better ) than the AN stuff. :yesnod:
Old Mar 2, 2004 | 06:56 AM
427V8's Avatar
427V8
Default Re: 427V8 -- Wilwood brakes (Corz)
I make a bracket that will allow you to use any 3.5" mount caliper from Wilwood, USbrake, Outlaw etc.
You still have to make sure they will fit inside your wheels though!
Old Mar 2, 2004 | 08:30 AM
Guru_4_hire
Cruise-In V Veteran
what calipers are you using? So I would have to order some rims with a 3/4 offset or some such thing
[Modified by Guru_4_hire, 8:56 AM 3/2/2004]
Old Mar 2, 2004 | 12:17 PM
LiveandLetDrive's Avatar
LiveandLetDrive
It's not a matter of offset, it's a matter of wheel design.
Old Mar 2, 2004 | 12:42 PM
427V8's Avatar
427V8
Default Re: 427V8 -- Wilwood brakes (RUXperienced)
Look at the pic below.
the caliper sticks out from the surface of the hub, about 1/4" more than stock.
It also is more square than stock so the wheel needs to have more of a step than stock.
This of course is a superlite6, it's about as wide as they get.
Other calipers are thinner
I don't know yet what wheels will fit, as I haven't got to that part yet...
Old Mar 2, 2004 | 12:43 PM
Guru_4_hire
Cruise-In V Veteran
pic?
step?
[Modified by Guru_4_hire, 12:45 PM 3/2/2004]
Old Mar 2, 2004 | 12:52 PM
Twin_Turbo's Avatar
Twin_Turbo
Not all, mine are 7.28" wide whereas the SL6 are anywhere from 5.51 to 6.08 depending on what disc width you ordered them for) I have 16" rims with quite a lot of space for calipers and I still need 15mm spacers.
[Modified by Twin_Turbo, 11:53 AM 3/2/2004]
Old Mar 2, 2004 | 12:59 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: 427V8 -- Wilwood brakes (Twin_Turbo)
spacers?
The calipers I want to use for the front are 5.85 wide.
but they are only 2.19 on the ouside of the rotor.
120-7570-FS(right) and 120-7571-FS(left)
these have a 1.88 and a 1.75 piston
the rears are 4.59
with 1.67 on the outside of the rotor.
PN 120-4998 Billet Dynalite 1.75 pistons
[Modified by Guru_4_hire, 1:06 PM 3/2/2004]
To 427V8 -- Wilwood brakes
Old Mar 2, 2004 | 01:16 PM
Twin_Turbo's Avatar
Twin_Turbo
yeah, spacers. Otherwise the wheel spokes hit the caliper..which is a bad thing :lol: The 15 mm is including some extra space tho, I can probably het away with 10 or 11mm but that would be too close for my comfort. My wheels are mag centers so when the spokes hit the calipers things start to disentegrate rather quickly. I have a spare wilwood integra 4 caliper (for parts) and 5 modular wheels so I have 1 spare wheel so I took that one apart and only mounted the wheel center on the hub with the caliper in place. that way I could use spacers of diff. thicknesses to select the one that suited me best.
Here's how I did it (the caliper isn't loaded with pads in this pic)
[Modified by Twin_Turbo, 12:16 PM 3/2/2004]
Old Mar 2, 2004 | 01:50 PM
Guru_4_hire
Cruise-In V Veteran
OK will they fit inside 15" wheels? or do I need to goto a larger Diameter?
Old Mar 2, 2004 | 07:46 PM
427V8's Avatar
427V8
Superlights will not fit. Others may.
You will need to measure twice and go to wilwoods site a bunch of times
