Water pump pulley size
Old Mar 2, 2004 | 11:49 AM
Jim Stewart's Avatar
Jim Stewart
Default Water pump pulley size
I've got an L46 350 that I want to put some chrome pulleys on. The stock water pump pulley is ~7 inches in diameter. The pulleys I have seen are all a little over 6 inches. Am I measuring mine wrong? If I use a smaller pulley this will increase the speed at which the water pump turns right?
Old Mar 2, 2004 | 12:06 PM
john V. zemba's Avatar
john V. zemba
Default Re: Water pump pulley size (Jim Stewart)
I may be wrong but not only increases it but the engine works less to turn it and yes another minimal increase in horse power . I may be way off on this but seem to recall someone telling me this.
Old Mar 2, 2004 | 12:07 PM
Fevre's Avatar
Fevre
Don't forget the vette w/p snout is 3/4", most stock w/p pulleys are for 5/8" snout unless noted otherwise. And yes a smaller diameter pulley will increase the speed of the pump but I am not sure what the stock diameter of the pulley is.
To Water pump pulley size
