Acid porting?
Old Mar 3, 2004 | 01:44 AM
75 Stingray!'s Avatar
75 Stingray!
Default Acid porting?
Well does anyone know anything about this technique?
What acid should I use on aluminum?
How long do I have to wait? (Not looking to take away much material, just make the ports consistent)
Do you have any pictures of the results?
Thanks!
Old Mar 3, 2004 | 02:33 AM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
Default Re: Acid porting? (75 Stingray!)
If you don't have good reason for it then pass. If you don't know what the "good reason" is then you don't have one.
Old Mar 3, 2004 | 03:20 AM
75 Stingray!
Default Re: Acid porting? (63Banshee)
I know what the good reason is! "Go ahead take my intake off! You'll just see stock ports" :)
I have done several searches and every time I end up getting told to buy a book for $50-100
I am not prepared to spend that much on a book for something that I might not even do.
Just trying to get a basic idea of what tools, products I need and possibly a very general cost.
Also why are you trying to deter me from performing this procedure? Is it dangerous, messy or simply a pain in the ars?
Old Mar 3, 2004 | 07:25 AM
comp's Avatar
comp
i'm with you on the $$ thing, i have pored meratic acid into iron ports, but
only left in over night, it smoothed some casting flash a little, maybe need to
leave about 3 days ??????? :skep:
Old Mar 3, 2004 | 07:48 AM
Pete79L82's Avatar
Pete79L82
It is less effective and more expensive to acid port something than to hand port it. The only reason to acid port a head is to get around a rule that says no porting and you are trying to hide what you are doing. If that is the need you have than let me know and I can go into more details. Otherwise it is much easier and cheaper to just use sanding rolls and carbide cutters to port with.
[Modified by Pete79L82, 6:49 AM 3/3/2004]
Old Mar 3, 2004 | 07:52 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Acid porting? (Pete79L82)
I agree with Pete. It is to hide your work and it is not controlable. Acid attacks area's of high stress quicker then other areas. I have done acid dipping to reduce weight, it takes alot of time to eat a noticeable area plus the acid keeps getting deluted.
Useing burrs takes no time at all but be careful and don't get carried away
Old Mar 3, 2004 | 06:50 PM
comp's Avatar
comp
Default Re: Acid porting? (norvalwilhelm)
I'M interest in info!!!! i was thinking :lolg: that the acid could "smooth & blend" the work after i;m done with the burr's (OK camo the work) :lolg: :lolg: there are some dirt track boy's that would be interested
in a set.... sence everybody does it :lolg: the thing is they all know the guy they are all going to, nobody knows me :thumbs:
Old Mar 3, 2004 | 08:37 PM
75 Stingray!
I'm still interested in finding out more.
Old Mar 3, 2004 | 09:21 PM
comp's Avatar
comp
75, we may be on our own :cry i was going to start on a iron 2bbl intake the
dirt boys have to run, seal it up ,pour in acid and check in 24 hrs and go from
there, oh do lite grinding first. sound like a backyard plan to you????
To Acid porting?
