Should I replace cam?
Old Mar 3, 2004 | 02:57 PM
TJRed76's Avatar
TJRed76
Default Should I replace cam?
This summer, I'm going to replace the aluminum single plane intake that came on my 76 with a dual plane. The current intake is just too much for the rest of the motor.
Here is my question. Since I have the intake off and access to so much stuff, should I replace the cam? I want it to be a nice driver, not a super hot racer.
What would be a good cam for general use driving?
Old Mar 3, 2004 | 06:57 PM
marshrat99's Avatar
marshrat99
Default Re: Should I replace cam? (TJRed76)
TJ: I'm using a XE262 in my slightly modified daily driver (see sig for details). The cam gives good performance, decent mileage and enough vacuum for my 79. If you do replace your cam, then you'll also want to at least replace your lifters. Be sure to check with the cam manufacturer to ensure you don't also have to replace your valve springs. If you go that far, it would be a good time to take a good inspect your entire top end. :cheers:
Old Mar 3, 2004 | 09:46 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
You need to provide more info here TJ. What is ur current cam? How many miles on current cam?
But removing the intake isn't even half the job. I just replaced my cam and it's a ton of work. Too much to describe here but plenty of books to help. Its not just the cam u end up replacing its the dozen(s) or more of old parts u need/break as u get into the job.
I've read stock cams are only good for about 135K mi before wear starts to reduce power.
Also read that the cams with 108 degree lobe separation angle (LSA) make the most mid range torque/power in 350" motor with stock heads. Only company selling cams on the shelf with 108* LSA is Iskenderian Racing Cams (Isky) and I like thier: Grind No./Type: 262-SUPERCAM, HYDRAULIC Low/Mid-Range performance cam. 9.5:1 compr. 3.08-3.70 axle ratio. Passenger cars & trucks. Up to 625 CFM Carb. RPM-Range: 2000-5500 Valve Lift - INT: .435 EXT: .435 Valve Lash Hot - INT: .000 EXT: .000 ADV Duration - INT: 262° EXT: 262° .050 Duration - INT: 208° EXT: 208° Lobe Center: 108°
:thumbs:
Unless your up to a big messy job send it to the local corvette shop and get to know them. :yesnod:
To Should I replace cam?
