Knocking and Pinging ??? Any ideas?
Old Mar 3, 2004 | 07:28 PM
C32B's Avatar
C32B
Default Knocking and Pinging ??? Any ideas?
My 69 350/350 has recently started knocking and pinging. To my knowledge nothing has been done by the previous owners to accomodate unleaded fuel. The previous owner advised me to run Amoco High Octane (93) and I would be fine. It ran fine through the summer and on my weekend outings until just recently.
Any ideas such as adding fuel additiive, octane boost, etc. or could it be something more terminal :confused:
Any advice is much appreciated!!
Old Mar 3, 2004 | 07:57 PM
Steve's74's Avatar
Steve's74
Default Re: Knocking and Pinging ??? Any ideas? (C32B)
It's possibly just the time of the year. The warm temperatures you are experiencing (me too) are out of line for this time of year, as the fuel companies are still utilizing "winter blend" fuels. A winter blend has a more volatile combination of hydrocarbons to make for smoother starts and running in the winter, and will ping on early motors without knock sensors when temperatures spike. It takes time for the gas companies to switch their stocks over. In another month, the pinging may go away just because of fuel blend changes.
Of course, you may have a mechanical condition causing the ping too.
Old Mar 3, 2004 | 09:57 PM
72ls5fla's Avatar
72ls5fla
Default Re: Knocking and Pinging ??? Any ideas? (Steve's74)
I agree with the fuel blend ..
My car can run dierent from state to state, all relavent to the gas I have in the car. I do add Lead Supreme 130 (real TEL addititve). I get about 95-96 octane leaded fuel for about an extra 25 cents per gallon.
The TEL additive seemed to negate the blend problem for me.
The company that sels the additive is called Kemco and located in Utah.
They sell the stuf by the case 12 x 32oz quart bottles.
I add 1oz per gallon.
Hope this helps some.
Bill
Old Mar 3, 2004 | 10:21 PM
JB's Avatar
JB
St. Jude Contributor
Could be carbon buildup in the cylinders causing pre-ignition. Try running a couple bottles of Techron additive through it, and if that don't do the trick, some folks swear by dribbling water or ATF fluid through your carb while it's running, just enough to almost but not quite stall it out.
JB
C32B's Avatar
C32B
Default Re: Knocking and Pinging ??? Any ideas? (72ls5fla)
Thanks guys for the input. I'm hoping you both are right but I'm going to monitor closely and get in the shop if it persists. It's the original engine with a prior rebuild (may be a different cam) and I'd like to keep it original. :yesnod:
Old Mar 4, 2004 | 07:27 AM
isosceles's Avatar
isosceles
Default Re: Knocking and Pinging ??? Any ideas? (JB)
Could be carbon buildup ....
JB
If you suspect carbon, use GM Top Engine Cleaner. You pour 2/3 of the can in with the motor running, then pour the last 3rd in real fast and the motor stalls. Let it sit for 15-20 min, restart (instructions on can). Do it on a breezy day because it causes lots of smoke. Other car manufacturers use it on some of their scheduled maintenences.
Old Mar 4, 2004 | 08:56 AM
SpyderD's Avatar
SpyderD
Default Re: Knocking and Pinging ??? Any ideas? (isosceles)
Hmmm, I never heard of the "winter blend" but it makes sense. I just had the same problem. 10.7 compression with the new engine installed in October so I always on the lookout for detonation and check the plugs for signs religously. Never had pinging until Saturday when the temps went up to the 60's and I heard some rattling going up a hill. I thought I got some bad gas.
I reduced the vacuum advance a bit and I may retard the timing a degree or two, so I am listening carefully for the pinging to return. One thing to note - just reducing the timing one or two degrees may make that pinging go away.
Old Mar 4, 2004 | 04:38 PM
terry82's Avatar
terry82
do a check on the timing, mine has moved before.
To Knocking and Pinging ??? Any ideas?
