Headlights not opening
Old Mar 8, 2004 | 08:19 AM
BLU 4ME's Avatar
BLU 4ME
Default Headlights not opening
Headights will not open with the switch. Will open will the override pull valve. Put 25 in of vacuum on the white to the system at the firewall to the lights no leaks. did the same into the car no leaks. Any clue as to what the culprit might be? I had a spare switch which I tried and still the same probelm. Thanks Stephen :mad
Old Mar 8, 2004 | 10:03 AM
R 73 454's Avatar
R 73 454
Default Re: Headlights not opening (7782vette)
I would double check hose connections on switch, if they are reversed, they don't work! Then make sure switch opens vacuum circuit when turned on by bench testing. :mad
Old Mar 8, 2004 | 10:59 AM
verskel's Avatar
verskel
Default Re: Headlights not opening (R 73 454)
:iagree: ...can't be the vacuum if the over-ride still sucks ! :jester
Old Mar 8, 2004 | 12:22 PM
BLU 4ME's Avatar
BLU 4ME
Put in new switch and lights are all better. :hurray: Thanks for all your help!!!
Old Mar 8, 2004 | 05:18 PM
verskel's Avatar
verskel
:party: Kudos to the Forum ! :party:
To Headlights not opening
