Brakes are done :-) :-)
Old Mar 13, 2004 | 10:57 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default Brakes are done :-) :-)
What is the best way to bleed the rears?? There's 3 bleeders.
And my wife quickly volinterd to to help.
:EDIT: spelling.
Old Mar 14, 2004 | 10:07 AM
Larsson's Avatar
Larsson
Default Re: Brakes are done :-) :-) (wackedvette)
The only thing I can contribute with here is that you should only use two bleeders per wheel, the two on the top.
The third one, next to the brakepipe should be a plug but many uses a bleeder instead for buying a special plug.
Atleast that's what I've heard. Bleed the outer right first, then the inner right, outer left and inner left.
There's a lot of info about bleeding brakes on the forum, do a search and you can sit reading for hours!
Old Mar 14, 2004 | 05:36 PM
79VetteMike's Avatar
79VetteMike
:EDIT: spelling.
Dude, you need to RE-EDIT yer spellin. :lol:
Old Mar 14, 2004 | 07:53 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Re: Brakes are done :-) :-) (79VetteMike)
TTT :thumbs:
To Brakes are done :-) :-)
