AFR Heads Arrived- Quick Question
Old Mar 14, 2004 | 09:02 PM
Les's Avatar
Les
Default AFR Heads Arrived- Quick Question
I took delivery of the AFR 195s that I ordered about 6-7 weeks ago- real pretty! They're not for my Vette though cuz I think I'd have trouble bolting em onto my bigblock ;) They're for the 355 in my 70 Z28. I had the local head guru set em up w/ better valves & check tolerances on seats- they checked out fine.
I don't really want to disassemble everything to re-torque the heads after start-up. He told me that when assembling it's acceptable to torque them once, wait an hour, back off the bolts & re-torque, wait another hour, & repeat the process one more time. Has anybody done it that way and, if so, did you have any problems with sealing? I fully intend to do it that way since he's so well respected but I'm just curious to hear from anyone who's done it that way. Thanks. :cheers:
Old Mar 14, 2004 | 09:10 PM
FEDX's Avatar
FEDX
From: A high school diploma fixing what a college degree broke TN
Default Re: AFR Heads Arrived- Quick Question (Les)
I dont understand how that method accounts for the expansion and contraction of the block/heads after starting up and cooling down? I have seen a similar method used on aircraft,but not anywhere there would be a heat buildup.Just my opinion,but to be on the safe side,I would re torque after running. :cheers:
Old Mar 14, 2004 | 11:20 PM
LT1driver's Avatar
LT1driver
Default Re: AFR Heads Arrived- Quick Question (FEDX)
I would retorque after hot and run, but best to call AFR and ask them what to do :cheers:
Old Mar 15, 2004 | 04:10 AM
comp's Avatar
comp
Default Re: AFR Heads Arrived- Quick Question (LT1driver)
:iagree: with LT1
Old Mar 15, 2004 | 04:40 AM
Les's Avatar
Les
Default Re: AFR Heads Arrived- Quick Question (comp)
:iagree: with LT1
Thanks guys- that thought crossed my mind after I posted this. I also found head bolts by ARP that don't require disassembly of the valvetrain to retorque them. I'll call AFR tomorrow & see what they say. :cheers:
Old Mar 15, 2004 | 04:41 AM
Fevre's Avatar
Fevre
Also consider what the head gasket and bolt manufacturers recommend.
Old Mar 15, 2004 | 06:58 AM
Matt Gruber's Avatar
Matt Gruber
yes i use that method. :cool: after 1 hour the gasket has compressed slightly, similar to running
Old Mar 15, 2004 | 08:07 AM
Pete79L82's Avatar
Pete79L82
If you use a good quality head gasket, such as a Fel-pro 1003, then no retorque is required. Fel-pro actually recommends that you do not retorque their Perma-Torque line of gaskets. I have not retorqued a head in over 10 years and have not had a head gasket failure in that time span either.
Old Mar 15, 2004 | 12:12 PM
no_radio's Avatar
no_radio
Default Re: AFR Heads Arrived- Quick Question (Pete79L82)
I didn't retorque my AFR195 heads, which were installed with FelPro (I think PermaTorque, whatever AFR recommended on their web site) head gaskets last January. Approximately 1000 miles plus 35 trips down the 1/8 mile and no problems whatsoever.
Jeff
Old Mar 15, 2004 | 01:22 PM
gkull's Avatar
gkull
Default Re: AFR Heads Arrived- Quick Question (no_radio)
Les - on all my aluminum head rebuilds I set the TQ value and then I drive it for about one week to do some settle in from heat cycles. Then I retorq them all.
I'm also using .020 copper head gaskets. Years ago I had a slight leak on the outboard head to block and ever since then I retorq. Once.
I'm also using ARP head studs instead of bolts.
Old Mar 15, 2004 | 01:55 PM
VETDRMS's Avatar
VETDRMS
Well, I'm happy with mine..but I had a rocker stud break on me last night (solid roller). Its poly lock bound up the one beside it and bent a pushrod, broke the lifter body, beat the valve up, and ruined the roller.
If i was you i'd replace their junk rocker studs.
Also, if you want to do a little grinding/porting you can get a fair amount extra out of them...
:cheers:
Old Mar 15, 2004 | 02:46 PM
gkull's Avatar
gkull
Default Re: AFR Heads Arrived- Quick Question (VETDRMS)
VETDRMS - When you have big springs and cam it causes rocker stud deflection. If you place a straight edge along your studs and if any of them deflect over .030 when the valve is fully open you need a stud girdle.
I've owned three different kinds of stud girdles and this Crane cams is one of the better units on the market.
Old Mar 15, 2004 | 02:57 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: AFR Heads Arrived- Quick Question (gkull)
VETDRMS, what do you mean? Just stick a grinder in there and start porting? I would not recommend this, most likely your head will flow less afterwards. porting is more of an art than a science, it takes years of practise to get the feel for what is right and what is not, combined with extensive flow bench testing. just attacking the walls with your grinder is a big NO.
The only heads you can do that with are stock heads or any other head that has terrible casting glash, large valve guide bosses and big ridges behind the seat. You can easily clean those thins up without the chance of messing it up, however that's not real porting. Porting is when you change the shape, volume and characteristics fo the port to get a gain in airflow.
Old Mar 15, 2004 | 03:35 PM
no_radio's Avatar
no_radio
I thought the whole idea of buying CNC ported heads was to eliminate the need for extra hand porting? I wouldn't touch my AFR heads, if I wanted additional porting I would take them to someone with a flow bench that had ported AFR 195s before, or send them back to AFR for their full competition porting.
Jeff
Old Mar 15, 2004 | 03:43 PM
VETDRMS's Avatar
VETDRMS
Default Re: AFR Heads Arrived- Quick Question (Twin_Turbo)
Wow, a touchy subject that's for sure. Sorry if I was misleading, I wasn't implying he should attack them with a grinder. I was implying that someone who knows what they are doing can make an improvement without taking a horrendous amount of time in the process. The fact is the CNC work on the street heads isn't that great. Its primary benefit is having equal sized runners/chambers. Due to casting artifacts even the CNC program doesn't accomplish this, although it is very close. There are some "left-overs" in the CNC program that can be removed and "cleaned up."
Sooo, without going into a huge debate. Bolt them on and have fun, I'm sure it will run great.
:cheers:
Old Mar 15, 2004 | 03:57 PM
Fevre's Avatar
Fevre
I bought CNC ported Trick Flow heads and the main gain was on the exh side but was noticable throught the lift range for both. Was def worth the $150 for the flow gains for someone who would have to pay to have them ported.
Old Mar 15, 2004 | 06:01 PM
Twin_Turbo's Avatar
Twin_Turbo
:cheers:
Oh, okay :) you're talking about a real pro porting job, in that case...yes there are good benefits to be had there but there's a big price tag on that too and there are heads out there that out of the box are outclassed by the AFRs but when ported by a pro can give more performance, simply because they are designed to be ported and have extra material in those areas (brodix and dart heads come to mind here)
Old Mar 15, 2004 | 07:12 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Is re-torquing(sp?) something that commonly done with aluminum heads ? On my 350 with the iron Sportman II's I have never had to touch anything on it :confused: The engine shop hasn't said anything to me about retorquing the new engine's heads (AFR's) but I know the felpro head gaskets they installed weren't cheap either at $72.
To AFR Heads Arrived- Quick Question
