Lock Wheel Nuts Stuck
Old Mar 14, 2004 | 09:44 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Lock Wheel Nuts Stuck
My lock wheel nut special lug seems to be stripped. I can't seem to get the lug off. Last guy must have power wrenched this thing on there. Can these be replaced? How else can I get this thing off? Vise grip and hammer? Is there a special tool to grip the round lug?
[Modified by Dk Met Grn 80 L82, 10:11 PM 3/14/2004]
Old Mar 14, 2004 | 10:06 PM
FEDX's Avatar
FEDX
From: A high school diploma fixing what a college degree broke TN
Default Re: Lock Wheel Nuts Stuck (Dk Met Grn 80 L82)
I have heard of people buying cars and not getting the puzzle locks with them,most take a cheap socket and hammer it over the outside and remove it that way.I suppose a vise grip could work also.
Old Mar 15, 2004 | 10:32 AM
moosie982's Avatar
moosie982
Default Re: Lock Wheel Nuts Stuck (FEDX)
Hi, A :smash: hammer and chisel worked for me, just be careful. :yesnod: Peace,,,,,,,,,,,,Craig
Old Mar 15, 2004 | 04:44 PM
Robert8096's Avatar
Robert8096
Default Re: Lock Wheel Nuts Stuck (moosie982)
Find a SnapOn dealer. There is a special socket made to remove them. Most good tire shops have them. When I purchased my 96 C4 it had wheel locks and there was no key in the car and the dealer had no clue how to remove them. I took it to a large tire shop and they removed them. With the special socket.
Old Mar 15, 2004 | 05:00 PM
NHvette's Avatar
NHvette
Default Re: Lock Wheel Nuts Stuck (Robert8096)
:iagree: Snapon tool works. So does welding a bolt to the end of it.
Vice grips will fail, due to the case hardened exterior.
Angle grinder will turn the round to a hex ... then socket it.
:seeya
Old Mar 15, 2004 | 08:27 PM
c3-4me's Avatar
c3-4me
Thats what I just did with mine! Works great! :cheers:
Old Mar 15, 2004 | 08:41 PM
Shark Racer's Avatar
Shark Racer
Default Re: Lock Wheel Nuts Stuck (c3-4me)
I've suggested this in the past and got railed by members for it...
Think about what you're doing to the suspension when you're hammering directly on the stud. :smash:
Welding a socket/nut on the end or otherwise is a much better idea... or have a professional do it. As long as they don't take a hammer to it...
-Steve
Old Mar 15, 2004 | 09:37 PM
lostpatrolman's Avatar
lostpatrolman
Default Re: Lock Wheel Nuts Stuck (Pacin'California)
You would be hitting the lugnut, not the stud. The force from the hammer is passed from the lugnut to the rim. Although it seems like alot of force and potential damage from a hammer, there is less overall force from a hammer then from a good strong kick. If you dont believe it, consider trying to break a piece of wood. Hitting it with a hammer wont break it, give it a good kick and the piece of wood breaks in half.
Old Mar 15, 2004 | 09:49 PM
Dk Met Grn 80 L82
Thanks for the responses. I guess I'll try some of these tips or find a shop that has the special tool.
Old Mar 16, 2004 | 12:29 AM
Mike Ward's Avatar
Mike Ward
Default Re: Lock Wheel Nuts Stuck (lostpatrolman)
So could you kick a nail into a piece of wood with your foot, without using a hammer? Hitting the lugnut with a hammer transmits almost the same force to the bearing as if you were hitting directly. Bad idea. No bearing is made to with stand static forces like that. :smash: :eek: :nonod:
Old Mar 16, 2004 | 02:32 AM
FEDX's Avatar
FEDX
-Steve
I personally wouldnt have a problem with it.Understand that I am not suggesting a sledgehammer into the side of your car though,I meant a socket nearly the size of the nut tapped/hammered over it.And as far as worries go,what about the electric current of the welder going thru the bearings? :jester It just never ends does it, :D
Old Mar 16, 2004 | 03:42 AM
Twin_Turbo's Avatar
Twin_Turbo
The hammer on ye old socket works great and it won't damage anything, you just hammer the socket on till it's tight enough to make it grab. I did this to remove 4 locks on my truck and I used the same cheap socket for all 4, that's how lightly I had to hammer them on. You can not ruin the studs, the wheel will take the punishing first and mine have no marks (chromed steel cheapy wheels)
the side load on the bearings from the hammer will probably be nothing compared to the load of the car cornering at a respectable speed and it's not like you're out banging the studs daily
the problem with the fancy tools is they always end up in the same spot where the key is and that place is somewhere you have never been :) :D
[Modified by Twin_Turbo, 2:46 AM 3/16/2004]
Old Mar 16, 2004 | 07:41 AM
77BuffaloVet's Avatar
77BuffaloVet
Be careful hammering a socket on to the lug nut...did it, turned the socket one turn and broke the stud... :rolleyes: I was kinda happy that the stupid locking lug nut was atleast off, but getting a new stud in on the rear wheel was a pita!!!
Good luck!
Old Mar 16, 2004 | 09:03 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
You can do it with an air chisel but ya gotta be careful. I had them on my truck wheels and after trying to take them off, they found a new home...
Old Mar 16, 2004 | 01:32 PM
lostpatrolman
Default Re: Lock Wheel Nuts Stuck (Aflac)
Mike Ward, i said total force, not direct pressure. I am not sure of the actual forces that a hammer and a kick can deliver but lets assume a hammer delivers 200 psi and your foot can deliver 50psi. A hammer head is only 1 sqare inch so the hammer would deliver 200 total pounds of force. A foot is around 27 square inches, so a kick would deliver around 1350 pounds of force. The only reason a hammer can pound a nail into wood is becuase its force is so much more focused. If you made a shoe that had a small heel in the center, your foot could pound the nail in also. I am not saying that no force will be transmitted to the bearings, the force that is transmitted will be minimal. I would worry more about the forces taking corners delivers to your bearings then a hammer hitting a lugnut.
[Modified by lostpatrolman, 6:35 PM 3/16/2004]
To Lock Wheel Nuts Stuck
