'79 Electrical Problems
Old Mar 15, 2004 | 05:43 PM
mf79vette's Avatar
mf79vette
2nd Gear
Default '79 Electrical Problems
Flashers, high beams, turning sigs and wipers are inop. Headlights work but go black when I switch to high beams. Horn, radio, brake, back-up, dome etc all work. Thereis a noise from under the dash when I try the wipers.
Appreciate any help.
[Modified by mf79vette, 5:44 PM 3/15/2004]
Old Mar 15, 2004 | 10:34 PM
wombvette's Avatar
wombvette
Default Re: '79 Electrical Problems (mf79vette)
WoW, sounds like several problems actually. Each problem is more or less unrelated. You will need to describe each symptom a little better for proper diagnosis. Start by checking the HL bulbs, dimmer or switch. Check all bulbs in the signal system. Check the ground on the wiper motor.
Old Mar 15, 2004 | 10:50 PM
toyvet1's Avatar
toyvet1
Default Re: '79 Electrical Problems (wombvette)
Had strange thing like that when the ground wire going to the bellhousing broke on my 79.....
Old Mar 16, 2004 | 12:04 AM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default Re: '79 Electrical Problems (toyvet1)
I'm blowing fuses to the instrument panel and tail lights. I feel your pain.
To '79 Electrical Problems
