How To Test Temp Gauage ?
Old Mar 15, 2004 | 07:45 PM
Roscoe's Avatar
Roscoe
Default How To Test Temp Gauge ?
How do you test a temp Gauge :confused:
[Modified by Roscoe's C3's, 7:47 PM 3/15/2004]
Old Mar 15, 2004 | 08:05 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: How To Test Temp Gauge ? (Roscoe's C3's)
You put the sensor in a pot of boiling water and hook it up the the cars gauge. Then the temp you read is 212' F
Old Mar 15, 2004 | 08:17 PM
Gordonm's Avatar
Gordonm
Default Re: How To Test Temp Gauge ? (427V8)
I checked mine with a infra red temp moniter. It gets you close enough. The temp moniter is more accurate then the gauge.
Old Mar 15, 2004 | 08:32 PM
427V8's Avatar
427V8
Default Re: How To Test Temp Gauge ? (Gordonm)
Too bad but you're wrong.
In order to be accurate with an IR you have to know the emissivity of the surface you are shooting. Even then you are only getting the surface.
The actual water temp can be very different than the head temp, most likely higher.
Using the gauge itself to calibrate, calibrates the whole system to a standard.
boiling water is very acurate ( unless your part of the CCC and do it up in the mountains !)
It's a lot cheaper and when was the last time you had you IR calibrated? Do you know it's long term drift ?
To How To Test Temp Gauage ?
