Sloppy Tilt/Tele!
Old Mar 15, 2004 | 11:38 PM
R 73 454's Avatar
R 73 454
Default Sloppy Tilt/Tele!
Anyone know which parts to order for a loose T/T column? It's not horrible, but when it's "locked" in position, you can wiggle it up and down a little more than I feel it should. Common? :eek:
Old Mar 15, 2004 | 11:51 PM
USA SHARK's Avatar
USA SHARK
Default Re: Sloppy Tilt/Tele! (R 73 454)
I have the same problem and when I took it apart, there were missing pieces, not to mention ball bearings all over.
I just bought a used column on ebay for under $100 and am hopeful that there will be the parts I need in it. From what I understand, it is difficult to find new internal parts for the column.
Good luck with yours, and if I'm able to repair mine, I'll post again with pics. If not, I'll be buying another column and replacing the whole unit.
Old Mar 16, 2004 | 07:32 AM
Jim Shea's Avatar
Jim Shea
Default Re: Sloppy Tilt/Tele! (USA SHARK)
My first paper that is posted at Terry Rudy's Corvette Faq websight has some simple tests that you can perform on your steering column to help identify your problems. Here is a link to the first paper:
http://www.corvettefaq.com/redir.asp?site=611
This paper will get you started. There are a total of three T&T papers and three line drawing pics that address disassembly and repair.
Good luck,
Addtional help is only a post or an eMail away.
Jim Shea
Old Mar 16, 2004 | 09:27 PM
R 73 454's Avatar
R 73 454
Default Re: Sloppy Tilt/Tele! (Jim Shea)
Wow, what a great link!!! I see you wrote a lot of the steering articles. amazing, I'll be spending a lot of time there. Thanks again!! :party:
To Sloppy Tilt/Tele!
