Blasted and now frame repair time!
All other frame dimensions are correct.
The sagging drivers rear says it all
The brace that is straight
The brace that is bent
Frame and welds ok on pass side
Drivers side shows bending of frame and seperation of the two fgrame pieces
Diff mount bracket needs some work
Pass side of frame at body seal. Need to add some extra metal here
More to come,
Craig
Take a close look at the front crossmember. It's the right time to throw a few
gussets in and weld the lower control arm brackets to the crossmember.
http://forums.corvetteforum.com/zerothread?id=765942
:seeya
I'll try to get him to do that as well. I don't know how much time he will want to spend but I should try to make sure all the important places are taken care off, like those lower a-arm channels. I can't even be in the garage when he welds because of magnetic fields, high voltage and I have an implanted defibrillator - I used to work around high power, high frequency RF and had to retire. BTW, I have been watching your project for a long time and I might need your advice when it comes to my birdcage. I already know the rocker channels are in bad shape.
Craig
