what makes a good head?
First off, I admire your desire to dive in, head first, and take on your car. It's the same thing I did, after I bought mine, and the education I received is invaluable.
To answer the head question, you have to first decide your goals and your budget. Your head will be determined by where you want to make the power. If you're looking for nice, driveable torque, you can get a lot of bang for the buck from a set of Iron GMPP Vortecs. A set of them, assembled, is like $799, with the manifold and fasteners!
If you're looking for a lot of top end, you might want to go with a nice set of high flowing aluminum heads. If you go to my website, you'll see a link to a ton of engine combos. They'll show you what each combo makes, and the parts that were used. I think it's a good place to start.
As far as cc's, you have two specs. The cc's of the combustion chamber will typically be 64 or 76. The smaller the number, the higher you can expect your compression to be, with a given configuration. The smaller number equates to a smaller compression chamber. Therefore, you have less area to squeeze the fuel and air mixture.
The second spec, is the amount of air the cylinder head can flow. The higher the number, the more air it will flow. If you're looking for top end power, you'll need to flow more air. Therefore, you're typically going to be looking at a higher dollar head, designed for racing. But you do so at the expense of streetable torque. You see, our cars pre-date variable valve timing. So we can choose one, the other, or something in between. For most driving, a lower flowing head, with a milder cam, providing streetable torque, makes more sense. But for some, this is not good enough...:reddevil
Good luck with it.
And remember, like anything else, it's the sum of the parts that makes the power. Great heads alone will do very little for you. You need a good cam to complement it, plus the right drivetrain to exploit it.
As far as studs and fasteners go, you're good with normal fasteners so long as you're staying with a normally aspirated, pump gas engine. Studs are great for nitrous applications, superchargers, turbos, and normally aspirated, high compression engines.
:cheers:
[Modified by joeveto, 7:39 PM 3/16/2004]
