Did I get ripped off???
Old Mar 17, 2004 | 10:28 PM
toyvet1's Avatar
toyvet1
Default Did I get ripped off???
The machine shop charged me $227 to remove and install all eight control arm bushings. And hot tank the four a arms. I provided the poly bushings. I was thinking maybe $125 to $145.What do other charge for this. I'm thinking I should have bought the press from Harbor Frieght and did it myself...
Old Mar 17, 2004 | 10:31 PM
72rdstr's Avatar
72rdstr
Default Re: Did I get ripped off??? (toyvet1)
Uhmmm, you don't need a press... Did mine with a vise.
Old Mar 17, 2004 | 10:33 PM
red79c3's Avatar
red79c3
No, yah didn't. The work on control arm bushings isn't exactly a five minute job, and it does have the name CORVETTE on it. I know guys that would charge $300 for just any old car...... You did not too bad. :hurray:
Old Mar 17, 2004 | 10:55 PM
thevetterisbetter's Avatar
thevetterisbetter
Default Re: Did I get ripped off??? (red79c3)
A press makes it a LOT easier. A vise will do the job and probably tear up your control arms a bit. A fair price, not a deal, but fair. I agree, since I did it myself, not a five minute job. Especially not the first time!
:cheers:
Old Mar 17, 2004 | 11:00 PM
GDaina's Avatar
GDaina
Machine shop here charges $5.00 per bushing to remove and $5.00 per bushing to install, to blast them $10.00 an arm...that comes out to $40.00 to blast them...$80 for the bushings...
Old Mar 18, 2004 | 12:04 AM
enforcer's Avatar
enforcer
I did that at home using only hand tools. No need for a press unless you reinstall rubber bushings.
Old Mar 18, 2004 | 12:15 AM
GDaina's Avatar
GDaina
Default Re: Did I get ripped off??? (enforcer)
Installed mine at home, rubber bushings using a big socket and a heavy hammer, torched out the old rubber
Old Mar 18, 2004 | 12:32 AM
Wrencher's Avatar
Wrencher
You did fine. It's the all in what you want. I charge one hour ($60.00 period) for any tank work because of the cost to run it (my overhead). You can scrape and steel brush etc., but caustic soda gets it all! You end up with a part ready to paint. Got time and expertise? Do it yourself. Otherwise, get help.
Hans
Old Mar 18, 2004 | 08:10 AM
John 65's Avatar
John 65
Default Re: Did I get ripped off??? (GDaina)
:iagree: Thats exactly what I did on 2 cars. No problems. IMHO I think you could have done a little better with the price.
Old Mar 18, 2004 | 08:22 AM
mfgaffney's Avatar
mfgaffney
A machine shop in SoCal did the cleanup and install of new poly bushings on mine for $50. I did the removal of the old. I think you need to understand that folks are in business, and anytime you can do something, or part of something yourself, you can generally be better off.
Old Mar 18, 2004 | 10:17 AM
NHvette's Avatar
NHvette
Default Re: Did I get ripped off??? (mfgaffney)
I little high but not outrageous, if you removed the control arms from the car.
If they removed and replaced them, then a good deal.
My shop (which mucked up one of my arms) would charge $50 remove,
$50 install, and $35 to blast 'em. So - maybe about $170.
Much more to take them off the car.
:seeya
Old Mar 18, 2004 | 10:25 AM
carnut114's Avatar
carnut114
Default Re: Did I get ripped off??? (John65,80)
I did the same thing but drill holes all around the old bushing then stuck a screw driver in it and turned it right out. I didn't like the torch method too slow and stinky.
To Did I get ripped off???
