front shock replacement - steps?
Old Mar 18, 2004 | 10:19 PM
fcoppola's Avatar
fcoppola
Default front shock replacement - steps?
from looking at it, this seems to be an easy job for a first timer...
Assuming the car is jacked up high enough to slide the shocks out:
1. unbolt top bolt
2. unbolt bottom bolts
3. slide old shock out
reverse steps for installation.
Am I missing anything? It seems to be very straight forward. I have never attempted replacing shocks, and already bought some gas shocks for the front. I hear the back shocks are much more complicated. Any help or sugguestions are greatly appreciated.
Old Mar 18, 2004 | 10:30 PM
Shark Racer's Avatar
Shark Racer
Default Re: front shock replacement - steps? (fcoppola)
Yep. You'll need an allen key and one of those spinny-wrenches to take the top nut off. You can do it with a regular wrench, but it's not as much fun. Also, you may need a small jack to hold the bottom in place when you torque the two bolts down.
I actually think the rears are easier than the fronts, but I just hate compressing shocks. The only problem with the rear is if your mount is seized up. If not, you're most definitely in the clear.
-Steve
Old Mar 18, 2004 | 11:11 PM
HDFLH67's Avatar
HDFLH67
Just replaced the original fronts and rears on my '75. Easy job; no problems! I also replaced my tie rod ends while I was at it HUGE improvement in sloppy steering!
Old Mar 19, 2004 | 02:02 AM
Disco_Mike's Avatar
Disco_Mike
1. unbolt top bolt
I replaced all four shocks in an afternoon last summer. Fairly straight forward.
Old Mar 19, 2004 | 10:22 AM
72GACRZR's Avatar
72GACRZR
AS Said not hard. If it's your first time take note:
1. unbolt top bolt
You will need the allen key or a pair of small vice grips to hold the threaded rod while you break loose the lock nut and then the nut. Pay attention to the order of the nuts, washer, washer direction(it has a top and bottom side), and rubber grommet(also top and bottom).
Should have lock washer under them. No surprises, just don't lose.
Carefully and again note position of washer, grommet, and etc
4. Set up washer and grommet for inside of top before pushing up into spring.
here's fun part, try to get top thru hole and the push up on bottom to attach bolts, half tight for now. May need small jack to compress shock, may not if arm strength is good. Now check top to see that the top grommet is properly seated in the hole. If so stack other grommet,washer, nuts and tighten. Go back and tighten bottom. you're done.
The back are eaiser except for reaching bolts and dealing with rusted connections, Spray with your favorite rust loosener and go for it.
PS: Be sure car is secure on jack stands or ramps before you go under it.
[Modified by 72GACRZR, 10:27 AM 3/19/2004]
Old Mar 19, 2004 | 10:27 AM
NHvette's Avatar
NHvette
Default Re: front shock replacement - steps? (72GACRZR)
A tip for getting the top nut off the front: don't.
If the nut does not remove easily due to rust,etc ...
I just snap them off.
Put a 9/16" deep socket on a long extension. Using the extension
like a torque bar, bend the shaft back and forth a few times until the
shaft weakens and breaks.
Note - make sure the socket is over the nut ... so it bends beneath the nut.
Much fast than wrestling with a rusty shock.
If the rears are not rusted onto the lower shock mount ... they are easy.
:smash: :cheers: :seeya
[Modified by NHvette, 10:28 AM 3/19/2004]
Old Mar 19, 2004 | 11:01 PM
USA SHARK's Avatar
USA SHARK
I've never worked on any car until I got my 77 last summer. I'm in the process of rebuilding the front suspension and just did the shocks, front and back, yesterday. Piece of cake! I wish the rest of the suspension and power steering rebuild was as easy. If I can do it, you can do it!
By the way, I'm having a blast and it's already starting to look good! :smash: I'll post some pics soon.
To front shock replacement - steps?
