If I park my vette for a few days the battery drains down and needs a jump start. Kinda like me on a cold Hawaiian day :rofl:
can anybody point me to what might be draining my battery. It only takes about 5 days were it won't start. There are no visable lights on, and only the clock is running. :confused:
I have a similar problem. 3-4 days of sitting. If I first drive the vette at night after it has sat for a few days, the battery gets very drained. Just charged it the other night after it nearly died at 2-3 stops before I realized the amp gauge needle was dropping way down if I sat at a light for too long. Got home and sure enough, when I hooked up the charger, the battery was drained. Checked fluid and put it on the charger for the night. Drove it today and no problems.
Check both your battery and alternator for fitness. Either can contribute to charging problems (alternator - if it doesn't suitably charge the battery prior to parking for a few days, battery - if it isn't taking/keeping a charge or drains easily). I've been through 3-4 alternators and almost as many batteries since purchase in '97. Unless you disconnect the battery, there WILL be a drain.
alarm or antenna - two high draw cuircuits that are hot with the key off - if either one doesnt work, it may be the problem - oh ya, i almost fergot that pesky dome light delay - dave
Get yourself what we call a test light. Unplug the positive side of the battery and plug the wire of the test light to the positive wire of the car with the other part of the test light on the battery positive. If you have a drain, the light will glow. Don't forget to wait for the courtesy light to shut off. If the test light is on, take the fuses out one at a time to see from what circuit the drain come from.
had a problem like that. The wire harness that plugs into the alternator was plugged in upside down. Still charged, but drained when the engine wasnt running.
I have removed the dome light delay timer. I am wairting for a shippment from Dr. Rebuild for a replacement timer. I am not sure if the wiring to the alternator is correct though. I had to fix a connector and when I plugged in the connector all was good. Then I noticed that my battery light was on and I switched the wires. The light went out and the car runs good. :grouphug:
