Can you MIG weld copper?
Mar 20, 2004 | 09:10 AM
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Wife wants me to construct a trellis for the garden made from copper pipe. The instructions show pieces being soldered together. Not joints mind you but two pieces of round pipe simply making contact??? :confused:
I have a MIG welder and thought it'd be easier to use that method? Does a MIG welder get too hot for the 1/2 inch copper pipe?
Len
Mar 20, 2004 | 09:33 AM
Re: Can you MIG weld copper? (Jughead)
can't MIG copper you have to solder or I think you can braze it
Steve
Mar 20, 2004 | 09:36 AM
No you cant copper will not weld with mig now if you had a tig welder you can but VERY diffocult good luck with the honey dooo list
Mar 20, 2004 | 09:42 AM
Re: Can you MIG weld copper? (MILO851)
Get silfloss rod ,,, can be used with propane and makes extremely strong butt joints ,,,,,,,,,,
gman :thumbs:
Mar 20, 2004 | 11:20 AM
You can use a small propane torch and some solder. You will not be able to braze it. Ask your wife if she would like it made out of steel, then you can get a MIG. :cheers:
Mar 20, 2004 | 04:52 PM
Re: Can you MIG weld copper? (rexx78)
What ya talking about, we braze copper all the time! Silfoss will be the better choice.
Mar 20, 2004 | 05:30 PM
Oldtimer
Coppper doesn't take well to being welded. Screw or solder it together or braze it. Why does it habe to be coppper?
Mar 20, 2004 | 10:24 PM
St. Jude Donor '09
Re: Can you MIG weld copper? (killain)
They say that if made of copper, it will age to a nice color but not rust. :confused:
Thanks, I'll try to get some of the silfloss.
Mar 20, 2004 | 11:20 PM
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Silfloss, works real nice. I put a Copper stand together for my wife to.
I used Mapp gas to heat it and propane to conect it. :thumbs:
[Modified by wackedvette, 11:21 PM 3/20/2004]
cooper ,
copper ,
mig ,
nitrous ,
pics ,
pipe ,
solde ,
weld ,
welded ,
welder ,
welding
