Need new clutch!!
Old Mar 22, 2004 | 02:05 PM
Smitty's75's Avatar
Smitty's75
Default Need new clutch!!
My throw-out bearing in my 75 is starting to sing a little tune,,can anyone give me some clutch, pressure plate, recomendations for stock 4speed with capabilities to about 375 HP????!!!!!!!
Old Mar 22, 2004 | 02:38 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Re: Need new clutch!! (Smitty's75)
Hays makes a nice clutch set up. I installed their street-strip clutch in my 71 behind the ZZ4, and it has worked perfectly from day one. I had a centerforce before, but it gripped too well. Occasionally it would stay gripped after I released the clutch. It caused my car to over rev a couple of times when I was racing.
Old Mar 22, 2004 | 02:42 PM
pws69's Avatar
pws69
Centerforce Dual Friction - very nice clutch. I beat one up in an 81 Jeep Scrambler with an 80 vette 350 in it - about 10 years and it never even hiccuped (never slipped either!).
Old Mar 22, 2004 | 02:45 PM
Fevre's Avatar
Fevre
Default Re: Need new clutch!! (pws69)
:iagree: Just make sure you set up the fork arm and pivot stud correctly, you need an ad pivot stud to get the geometry right so if you order one get the Lakewood adj pivot stud with it, save you some time. :thumbs:
Old Mar 22, 2004 | 03:55 PM
Solid LT1's Avatar
Solid LT1
Default Re: Need new clutch!! (Fevre)
I would go with Centerforce, Hays last time I checked was re-boxing Valero clutches about 3yrs ago. YOU MUST! stay on top of your pedal freeplay until the Centerforce clutch is properly broken in (can take up to 3,000 miles.) The clucth disk wear causes the diaphram fingers to move rearward as the disc wears and if freeplay is not properly adjusted, a Centerforce will start to un-load when the RPM gets high and the weights bring the fingers even further back: The WORST CASE Scenario! for clutch wear. I have a dual friction in my 72 LT-1 that is used for autocross and has been Drag raced several times with slicks and is still holding up well (2800-3000 RPM starts at the strip are not easy on equipment!)
Old Mar 22, 2004 | 04:17 PM
LOTAHP's Avatar
LOTAHP
Default Re: Need new clutch!! (Solid LT1)
With 375 hp all you may need is a Ram or Hayes street/strip combo. The centerforce DF might be a little more than you need. Just sold that last week in C3 parts for sale
Old Mar 23, 2004 | 12:08 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Try luke clutches for about $150 buys everyting. Bought mine through Northern Auto Parts mail order. You can easily spend twice as much money but you won't buy twice as much clutch. :lol:
Old Mar 23, 2004 | 01:35 PM
pillowmeto's Avatar
pillowmeto
Default Re: Need new clutch!! (cardo0)
Now that the good ones are mentioned, in the the name of cheapness, ill present this one
PAW has RAM clutch kits for 127.95
10.5" GM
includes
pressure plate
clutch disc
throwout bearing
alignment tool
hope this helps
MAtt
To Need new clutch!!
