well this SUCKED!!!!
Old Mar 22, 2004 | 04:36 PM
munday's Avatar
munday
Default well this SUCKED!!!!
hooked up the carb, put on the demon braided steel fuel line i had laying around and tossed the chrome orielly's unit...cranked it over for about 10 sec to get the fuel in...then sprayed in some starter fluid and went to crank again and the passenger side of the engine caught fire...flames were orange which i am guessing is fuel...I acted fast and was able to put out the fire with a hose i had laying next to the car....fire extinguisher was to far away.
I didn't hurt anything, or so it seems. Flames were about 2-3 feet high off the engine.
Hopefully it's safe to try and start in just a little while.... I am worried about what caused it. I took the carb off about 4-5 days ago...could i have spilled some fuel and it still have been there? I think I heard a small intake backfire.
Old Mar 22, 2004 | 04:44 PM
munday's Avatar
munday
Default Re: well this SUCKED!!!! (munday)
okay i just soaked everything below the carb in simple green in a hope to get rid of and risidual fuel....I will rinse in about 10 min.
Old Mar 22, 2004 | 04:56 PM
stingraymaniac's Avatar
stingraymaniac
:eek:
that could have gone wery bad!
dont think that it was any fuel left after 4 days,then you must have spilled alot!
Must have been a backfire and a flodding carb ore something.
Old Mar 22, 2004 | 05:00 PM
zzyzx's Avatar
zzyzx
Default Re: well this SUCKED!!!! (stingraymaniac)
Scary! :eek:
Old Mar 22, 2004 | 05:05 PM
munday's Avatar
munday
Default Re: well this SUCKED!!!! (zzyzx)
found the problem. i went out there and tried to start again.....my bg fuel line is shoot fuel out in a stream thats about 3 feet long!!! i guess i will be going back to the chromie...
Old Mar 22, 2004 | 05:09 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Careful!!
:eek:
Old Mar 22, 2004 | 05:22 PM
munday's Avatar
munday
Default Re: well this SUCKED!!!! (Cali,68,L-79)
got it figured out and hopefully fixed......in the back of my bg line i didn't have the line tightened down...i was a dumass and tightened it down the same as the primary side which is different.
Old Mar 22, 2004 | 05:26 PM
78 Vette's Avatar
78 Vette
:eek: :crazy: :eek:
Old Mar 22, 2004 | 05:43 PM
Jack71's Avatar
Jack71
Default Re: well this SUCKED!!!! (78 Vette)
Glad you nailed that one.... good thing the wifey didn't see those flames. :nono:
Old Mar 22, 2004 | 09:03 PM
motown 71's Avatar
motown 71
Default Re: well this SUCKED!!!! (Jack71)
Good to hear this wasent worse !!
I know that feeling of fire....it is a bad, bad thing !! :nonod:
Old Mar 22, 2004 | 09:06 PM
SharkAttack's Avatar
SharkAttack
Yikes! Glad you and the car survived unharmed.
Old Mar 22, 2004 | 09:10 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: well this SUCKED!!!! (SharkAttack)
I had a little fire several months ago as well. Had just installed a fire extinguisher and it paid for itself that day. :)
Old Mar 22, 2004 | 11:08 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Sheesh. I bet your heart has never beat so fast...
Old Mar 23, 2004 | 01:27 AM
Disco_Mike's Avatar
Disco_Mike
:iagree:
Old Mar 23, 2004 | 02:23 AM
jetlag's Avatar
jetlag
Default Re: well this SUCKED!!!! (LesTalent)
That sucks! I've had that incident before, on an 85 Pontiac Fiero, caught that little thing on fire. I laughed so hard it brings a tear to my eye.
Old Mar 23, 2004 | 05:50 AM
Jvette73's Avatar
Jvette73
So what do you think ignited the leaked gas? I assume the engine was cold so it wouldnt have been a hot exhaust. Make sure your ignition wires are in good shape and all your electrical connections are good. That gas needed a spark to ignite. Ive spilled and leaked gas several times in the past. I guess I got lucky since it didnt light off.
Old Mar 23, 2004 | 12:29 PM
desi's Avatar
desi
Default Re: well this SUCKED!!!! (Jvette73)
..... Make sure your ignition wires are in good shape and all your electrical connections are good. That gas needed a spark to ignite. ....
:iagree: I would change all wires on that side at least. You can never be too careful
To well this SUCKED!!!!
Old Mar 23, 2004 | 12:41 PM
verskel's Avatar
verskel
:eek: Whoa dude !.....2-3 foot flames ?!? - OMG :eek: :crazy: :eek: :crazy:
I've had a 1-foot flame shoot out of the carb. but that's really scary.
Now that everything's calmer.......too bad you didn't have a video. :jester
....and at least now you can say your engine is flame tested too. :rofl:
Okay I'm :leaving:
Old Mar 23, 2004 | 01:05 PM
munday's Avatar
munday
Default Re: well this SUCKED!!!! (verskel)
the fuel was ignited by a intake backfire i believe...
Old Mar 23, 2004 | 04:11 PM
zzyzx's Avatar
zzyzx
Trying to find a cure for this problem....see this thread
http://forums.corvetteforum.com/zerothread?id=782542
