Pulled the distributor off, it was all gummed up.
Cleaned all the corrosion off. The springs snap back like new.
Put it back on and it won't start. :cry
I thought I put it back on the way I took it off, but; now I'm doubting myself.
I pulled it back off and switched it. (about 100 times)
It only goes on 2 ways that I can tell.
If it doesn't align at the bottom with that slot on the thing that drives it, it won't go down all the way.
Any ideas?
:confused:
Set the engine to TDC by the timing mark. Turn the rotor so that it will point to #1. You may have to turn the oil pump sloted shaft in order to get the distributor seated. Start it and set the timing.
Remember that when you align the timing mark to 0 on the scale the engine could be in either of two positions. TDC on the exhaust stroke or TDC on the compression stroke. To make sure its on the the compression stroke, remove the #1 plug, put your finger over the hole and have someone bump the engine with the starter in quick bursts. Very short cranks. When you feel the compression blowing out on your finger you know yur comming up on the compression stroke. At that point, as long as the mark hasnt already gone past the 0 mark, turn it by hand untill it lines up. Then your at TDC on the compression stroke. Then drop the dist in with the rotor lined up with #1 wire on the cap.
I had to turn the oil pump intermediate shaft as well. The dist gear turns quite a bit when you pull it out. I think it turns the oil pump shaft with it.
