Throttle Cable?
Old Mar 25, 2004 | 08:24 PM
Taijutsu's Avatar
Taijutsu
Default Throttle Cable?
I noticed that my t-cable had too much slack in it. It looks like it somehow partially let go from its linkage. I tried to get my head under the dash to see the problem, too tight. Before I take out the pedal and linkage, what will I find?
Rick
Old Mar 25, 2004 | 08:34 PM
Larry B.'s Avatar
Larry B.
Default Re: Throttle Cable? (Taijutsu)
The rod and bracket under the dash tend to bend over the years of lead footing and then you dont get full throttle. You need to bend the rod and or bracket so you get full throttle at the point at which the pedal is almost on the floor. This a very common thing
