Wireless Ignition System
Old Mar 25, 2004 | 08:53 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Wireless Ignition System
It's been a long day, so my mind has been drifting to Vette projects. I am working on a wireless ignition system to do away with unsightly plug wires by retrofitting my Linksys wireless router. With 5 ghz and fiberglass panels I should be able to mount the unit in the rear storage compartment. I will be using 8 of these units, one for each cylinder, each with its own IP (ignition pulse) address. I first thought I could use just one unit in a network configuration, but I fear a potential crossfire situation. Comments from others showing how I can avoid this would be appreciated.
Chuck
Old Mar 25, 2004 | 09:00 PM
GDaina's Avatar
GDaina
Default Re: Wireless Ignition System (Chuck Harmon)
I see one major flaw...using the wireless system, you open yourself to a security breach...hackers will be able to steal your pulse, thus leave you stranded by the side of the road.....Chuckster, Chuckster, you need to get a firewall, stand alone router, reroute the signal that it goes through a lead conduit, that means eight of the conduits...will be an unsighlty sight but, I suppose that can be routed under the chassis...now...how ya gonna terminate the lead conduits? I know...you will have to devise a spark receiver, the shampe of the Champeeeeeen spaaaak plugs...let me know how the project progesses....sounds sweet....I bet you could make a cool mil if it works...
Old Mar 25, 2004 | 09:02 PM
GDaina's Avatar
GDaina
Default Re: Wireless Ignition System (GDaina)
:skep: um...the typing... :leaving:
Old Mar 26, 2004 | 12:07 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Good luck Chuck! :lol: :lol: :lol:
Old Mar 26, 2004 | 12:59 AM
Shark Racer's Avatar
Shark Racer
Chuck, I'm your friend and I hate to have to say this to you, but have you ever heard the phrase:
"Shut up and drive!" ?
:D I heard that there was thunder in the Blossom Hills last weekend. I may stop by Tom's house sometime, you better be ready on a moment's notice to fire up the blue car!
-Steve
Old Mar 26, 2004 | 01:54 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Wireless Ignition System (Pacin'California)
I want some of what he is smoking..... :crazy: :lol:
Old Mar 26, 2004 | 02:01 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I hate unsightly wiring as much as the next guy. I don't think security will be a problem as long as you use 128 bit WEP, and don't stay in one place long enough for someone to de-coded the signals from your routers to your IP endpoints. If security is a major concern you can try to do a VPN to each cylinder. Can you do a dynamic IP for each cylinder, or will you have to have a table? I would like to see dynamic, that way you can un-address some cylinders when not needed (downhill) and maybe free up those addresses for others that need them.
Just make sure your Part 15, Class B, Sec. 15.247 and 15.109 FCC compliant. The FCC has been cracking down lately and I don't want to see you have to cut down your transmitter's modulation rate-output power.
Old Mar 26, 2004 | 02:38 AM
Chuck Harmon
Default Re: Wireless Ignition System (BSeery)
If security is a major concern ....
Yes it is, especially if I want to mount the router in the rear. I'm not sure it will work with the firewall protection operational.
I take offense at being accused of smoking something! I don't smoke around 114 octane gas! As for inhaling too many fumes, "I never inhaled!"
Chuck
Old Mar 26, 2004 | 02:44 AM
Chuck Harmon
Pacin,
Yes, there is fire in them cylinders! Let me know when you might be by, it is a pretty busy weekend.
Chuck
Old Mar 26, 2004 | 03:24 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
I dont see how this would cause you problems???????
Old Mar 26, 2004 | 03:25 AM
Shark Racer
Default Re: Wireless Ignition System (Desertdawg)
V-16!!!
Old Mar 26, 2004 | 08:31 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Chuck,
I think you need to run a Linux fierwall /web proxy on each plug wire. That way you can tune you car via the internet.
With one box per plug it'd work great!
Not sure how you'd get 8 pc's in the engine compartment tho...
Old Mar 26, 2004 | 09:00 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Why use wireless you can always try fiber optics. You just need to get some Single mode fiber since it uses LASER it would be really good!!
To Wireless Ignition System
