AIR system
Old Mar 26, 2004 | 09:08 PM
JDRez42's Avatar
JDRez42
Default AIR system
I'm planning on getting my cats on tommorow and getting my car e-checked. Last e-check for this car for as long as i own it so i was thinking i would just get rid of all the emissions junk if it would help free up a little power. My question is can i disconnect the AIR system without any ill effects to the engine such as vacum or anything else, though i don't think it has any vacum hook-ups right? The cats are coming back off as soon as it gets back from e-check.
OT Blew motor in work truck and had to put in a reman. motor. I have never done anything that extensive so after i got the motor swapped and running i took it to a shop so they could make sure everything was working properly and they said everything looked good. Awesome!!
Sorry long post :sleep:
Old Mar 26, 2004 | 09:32 PM
trw's Avatar
trw
Default Re: AIR system (JDRez42)
You can unhook the AIR system without any ill effects.
You will free up about 1 or 2 HP.
The AIR system only uses the pump to pump air into the exhaust.
Hope this helps.
Terry
Old Mar 26, 2004 | 09:55 PM
JDRez42's Avatar
JDRez42
so no power but less cluter is good enough for me
thanks
Old Mar 26, 2004 | 10:31 PM
R 73 454's Avatar
R 73 454
What year are you working on? :confused:
Old Mar 26, 2004 | 11:18 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Re: AIR system (R 73 454)
one of the coolest and slowest....1980 :thumbs:
To AIR system
