Adjustable strut rods
Old Mar 29, 2004 | 10:15 AM
82Red's Avatar
82Red
Default Adjustable strut rods
Are 'adjustable' strut rods absolutely necessary when droping the rear end a couple of inches (with 10" bolts)?
Old Mar 29, 2004 | 12:59 PM
JJ Deuce's Avatar
JJ Deuce
Default Re: Adjustable strut rods (82Red)
I imagine. There's not enough adjustment with the stock rods to account for all the neg. camber. I only went to 8" bolts, and had to install the adjustable strut rods.
Old Mar 29, 2004 | 03:09 PM
markdtn's Avatar
markdtn
Default Re: Adjustable strut rods (Jeff 6T9)
Adjustable rods are a wonderful addition anyway, well worth the expense.
Old Mar 29, 2004 | 03:53 PM
R. Bruno's Avatar
R. Bruno
Default Re: Adjustable strut rods (markdtn)
:iagree: If you really want to go all out, get the rods w/ heim joints from Vette Brakes , a Forum vendor.
Old Mar 29, 2004 | 04:02 PM
NHvette's Avatar
NHvette
I have the adjustable strut rods - and they are great.
However, it does not make sense that longer spring bolts will require them.
People add the longer bolts, because their car sits too high with a new (usually 'glass) spring.
The longer bolt allows the car to be lowered to the proper body height.
If this is the case for you, then the wheel and differential will be in relatively
the same spot.
In other words, if you haven't significantly changed the body height (or tire
diameter) ... the camber should be about right - and definitely adjustable with
the stock strut rods.
:seeya
To Adjustable strut rods
