68 steering column
Old Mar 30, 2004 | 07:25 PM
BFry's Avatar
BFry
Default 68 steering column
Could someone go through the steps to lower the steering column on a 68. I need to remove my tach and speedo and don't want to screw anything up.
THANKS
Old Mar 30, 2004 | 07:28 PM
Corey_68's Avatar
Corey_68
Default Re: 68 steering column (BFry)
There should be 4 bolts hold up the column. Once it's dropped you'll have acess the the Tach and speedo. :cheers:
Old Mar 31, 2004 | 12:49 AM
LemansBlue68's Avatar
LemansBlue68
Default Re: 68 steering column (Corey 68)
You may also want to loosen the two bolts near the floorboard. No need to take them out--just loose. You don't want the entire weight of that column prying on your floor and possibly cracking it. I don't remember if you have to take it loose from the steering box coupler as well. It's been a while since I dropped my column. I took it all the way out.
Old Apr 1, 2004 | 05:48 AM
BFry's Avatar
BFry
Thanks for the input
To 68 steering column
