how about hiding your kill switch here?
Old Mar 31, 2004 | 04:31 PM
Todbo's Avatar
Todbo
Default how about hiding your kill switch here?
too obvious? or hide it in plain sight
Old Mar 31, 2004 | 04:39 PM
Fevre's Avatar
Fevre
Default Re: how about hiding your kill switch here? (Todbo)
Looks like a good spot to me. :steering: I use a lighter for my splifs anyways. :jester
Old Mar 31, 2004 | 04:45 PM
Brettmc's Avatar
Brettmc
I say do it. Good spot.
Brett :thumbs:
Old Mar 31, 2004 | 05:27 PM
Glensgages's Avatar
Glensgages
When I bought my '82, it had a 'kill' switch up-under the dash-board.
I let a buddy drive it once; his Size 14 feet accidently turned it 'OFF', and we couldn't figure-out what'd happend
:confused:
:leaving:
Old Mar 31, 2004 | 05:35 PM
78 Vette's Avatar
78 Vette
Default Re: how about hiding your kill switch here? (Glensgages)
:lolg: :rofl:
How long till you figured it out?
:confused:
:leaving:
Old Mar 31, 2004 | 05:40 PM
Glensgages's Avatar
Glensgages
Default Re: how about hiding your kill switch here? (78 Vette)
:lolg: :rofl:
:confused:
:leaving:
A few tenderonies had stopped-by as we 'diagnosed' :confused: the problem, so we tried to make it look REAL 'technical'.....
:bb
Old Mar 31, 2004 | 06:02 PM
Corey_68's Avatar
Corey_68
Maybe it's just me, but that would be one of the places I would look if I were stealing a car. :yesnod:
Old Mar 31, 2004 | 06:17 PM
pillowmeto's Avatar
pillowmeto
looks good, thats where mine is.
But i actually modified the existing cigaratte lighter to work as the kill switch
MAtt
Old Mar 31, 2004 | 06:23 PM
Todbo's Avatar
Todbo
Default Re: how about hiding your kill switch here? (pillowmeto)
MAtt
now that's an idea :cheers:
Old Mar 31, 2004 | 06:32 PM
Brown78's Avatar
Brown78
:nono: Thats to easy to locate. I think. Under the dash is good place. But, that is where most alarm shutoff's are located. I put mine right near the %#$%^&^&^%()_++_%$. Behind the @$&**$#%*(()&%#$#^&^& :lol: :lol: Every person that gets into the car with you will see you stick your finger in the ashtray. NOT GOOD! :nonod: Install it wear I put mine. :seeya Steve
Old Mar 31, 2004 | 08:15 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Re: how about hiding your kill switch here? (Brown78)
I would also say too obvious in the ash tray. Mine is pretty plain under the dash by the headlight switch, but mine uses a barrel key to activate it. Not that it's that difficult to start cutting wires under there, but it takes time to fiddle with it.
Old Apr 2, 2004 | 12:02 PM
Todbo's Avatar
Todbo
Default Re: how about hiding your kill switch here? (Buffalo Dude)
ok, I liked pillowmeto idea of modifing the cig lighter, but after seeing all the feedback about the ashtray i've decided to go with a pressure pad connected to a realy on the starter , hide it in your favorite place under the carpet , unless you put pressure on this pad "the car no start" :nono:
Old Apr 2, 2004 | 12:46 PM
427basketcase's Avatar
427basketcase
A Buddy of mine cut up a junkyard radio, using the front part as a dual-purpose delete plate that looks factory. Anyway used a wiper switch instead of the on/off/volume control and passed the ignition cutoff through it. Now it will only start when the "Radio" is on. The nice thing about that is that it only takes a bump to turn on the switch, so it can be done relatively unnoticed.
This was an alternative to an expensive delete plate and it looks factory.
:thumbs:
Old Apr 2, 2004 | 10:37 PM
73ragtop's Avatar
73ragtop
If your factory alarm keyhole is in a good spot, wire it to the two terminals there; on a 1973, a thief would virtually have to remove the gas tank to get to the back of the switch. You can also interrupt a circuit to your electric fuel pump there, if you wish.
[Modified by 73ragtop, 9:40 PM 4/2/2004]
Old Apr 3, 2004 | 01:17 AM
comp's Avatar
comp
Default Re: how about hiding your kill switch here? (73ragtop)
put big letters on that say Vibrator Girlie Man :lolg: :lolg: then wire it to
a shock system :hurray: :hurray: :hurray:
Old Apr 3, 2004 | 01:32 AM
pillowmeto's Avatar
pillowmeto
But i actually modified the existing cigarette lighter to work as the kill switch
MAtt
i can push the cigarette lighter in and keep it that way, as if i were letting it get hot, incase i need to take it to valet, like thats ever going to happen, or take the lighter out and keep it in my pocket so its basically unstartable. Looking in the socket it looks normal, and looking at the lighter there are only a few small clues that give it away
If you didn't already know, you never would.
MAtt
Old Apr 3, 2004 | 12:22 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Sounds good.
To how about hiding your kill switch here?
