Brake question (not bleed order!) Help!
Old Mar 31, 2004 | 07:31 PM
wcsinx's Avatar
wcsinx
Default Brake question (not bleed order!) Help!
Ever since I bought this car, I've had excessive (~6 inches) pedal travel before the brakes even began to catch and I got any pedal feel at all. Once I was past that point, they were always fine though ... good'n strong. Anyhow, I figured I just needed a new master cylinder ... prob. just blowing past the first seal right? Errrr ... no
I just pulled off the MC, and it looked relatively new. There was no leakage into the booster hole. The bore was clean. The seals were all in good shape, etc.
Sooooo I get in the car, hit the brake pedal, and my partner in crime noticed that the booster rod wasn't even moving until I got past my 6 inches of dead pedal. That can't be right. :confused: Everything appeared to be in order under the dash as far as the pedal to rod linkage. So I have no idea right now. Do I just need to do a LOT of adjustment on the pedal, or did someone install the wrong vacuum booster, or what?
TIA! :flag
[Modified by wcsinx, 12:32 AM 4/1/2004]
Old Mar 31, 2004 | 07:48 PM
78 Vette's Avatar
78 Vette
Default Re: Brake question (not bleed order!) Help! (wcsinx)
You may be right about the booster.
That rod should move as soon as you hit the pedal.
Old Mar 31, 2004 | 10:20 PM
wcsinx's Avatar
wcsinx
Default Re: Brake question (78 Vette)
I sure thought so! It's good to know I'm not crazy. :D Is there that much adjustment in the pedal though, or could it only be the wrong booster?
Old Apr 1, 2004 | 08:58 AM
wcsinx's Avatar
wcsinx
TTT
nobody has any idears?
Old Apr 1, 2004 | 09:07 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Brake question (wcsinx)
Could it be that maybe someone added a booster to a non PB car. I think there is a difference in the manual and power brake master cylinders. Hopefully someone will chime in and back me on this one.
Hello....anyone....hello
Old Apr 1, 2004 | 09:13 AM
wcsinx's Avatar
wcsinx
Default Re: Brake question (Eddie 70)
I don't think there were any 76's without PB. at least according to ... http://www.idavette.net/facts/76.htm
Yeah, the MC is definitely different for manual and power brakes, but that should not affect the booster rod travel. :confused:
[Modified by wcsinx, 2:19 PM 4/1/2004]
Old Apr 1, 2004 | 10:11 AM
GDaina's Avatar
GDaina
Just finished working on a 67 GTO, the 67 had an adjustable rod travel...can the vette's rod be adjusted?
Old Apr 1, 2004 | 10:38 AM
wcsinx's Avatar
wcsinx
Default Re: Brake question (GDaina)
I think the stock clevis/rod has a small amount of adjustment in it, but I can't imagine it being enough to take up that much pedal slack. Then again, I haven't made a thorough inspection of the works under there yet. Maybe Bubba got ahold of an aftermarket unit with a lot of adjustment potential and just spun the clevis all the way down the rod not knowing any better. :confused:
I'll post some pictures this weekend if I can't figure out what's going on here.
Sooooooo :confused:
Old Apr 1, 2004 | 10:57 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
There is a possibility of 2 different master cyl's. One has a shallow hole in the piston the other has a deep hole. Remove the master cyl. and push the rod all the way into the booster. if it goes back past the face then you need the shallow piston. if it stick's out about 1" then you need the deep piston.
The wrong master will cause this problum! :)
Old Apr 1, 2004 | 11:03 AM
wcsinx's Avatar
wcsinx
Default Re: Brake question (VBP)
Yeah, I know about the two different MC/Booster styles. Mine is the deep hole, and I have verified that the booster is properly mated to the MC.
To clarify, the rod coming out of the booster which goes to the MC does not move until I push the pedal past ~6" of slack travel. So this says to me that the slack is somewhere between the pedal and the firewall side of the booster. Am I thinking correctly?
Old Apr 1, 2004 | 11:57 AM
GDaina's Avatar
GDaina
You will be surprised how little adjustment will take up the slack...same thing on the GTO, pedal went to the floor, and a 3/4" adjustment in the travel fixed it. I would try adjusting the travel first before pulling appart the MC
Old Apr 1, 2004 | 12:05 PM
wcsinx's Avatar
wcsinx
I sure hope that's the case. Hopefully I won't have to pull the booster to adjust it though.
too late :lol: I was convinced that was my problem, before we noticed the rod wasn't moving correctly.
To Brake question (not bleed order!) Help!
