Exhaust tips keep coming loose
Old Apr 1, 2004 | 10:47 PM
DropTopBigBlock's Avatar
DropTopBigBlock
Default Exhaust tips keep coming loose
I've got a '71 with stock exhaust, and one of the tips keeps vibrating loose, no matter how much I tighten the little u-shaped yoke thing where it goes into the muffler. Any advice on keeping it in place? Loctite?
Please help!
Old Apr 2, 2004 | 07:13 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Default Re: Exhaust tips keep coming loose (DropTopBigBlock)
maybe try pop riveting in?
Old Apr 2, 2004 | 09:00 AM
SharkAttack's Avatar
SharkAttack
Have you tried brand new stainless split washers on both sides of the U-bolts?
Old Apr 2, 2004 | 01:24 PM
HDFLH67's Avatar
HDFLH67
I welded the back three pieces and eliminated those clamps all together!
Old Apr 2, 2004 | 01:48 PM
stingraymaniac's Avatar
stingraymaniac
Default Re: Exhaust tips keep coming loose (HDFLH67)
isnt it most simple to weld them? :smash:
Old Apr 2, 2004 | 03:57 PM
Willis's Avatar
Willis
Default Re: Exhaust tips keep coming loose (stingraymaniac)
:iagree: Weld It, A couple of tack welds will work wonders
Old Apr 2, 2004 | 04:47 PM
DropTopBigBlock
Default Re: Exhaust tips keep coming loose (Willis)
Welding may be the way to go: even when I get the tip in, it rotates around in the pipe, and looks fowl-eyed. I'll try the split washers, and if that doesn't work, well, time for the torch!
thanks!
Old Apr 8, 2004 | 03:44 PM
DropTopBigBlock
Finally got it, guys: once I figured out the U-shaped clamp was nothing but a hanger (amazing what you figure out when you crawl under these things!), I lined up the little divot'n'groove arrangement in the pipes and tapped it in with a mallet: no problem now.
Thanks for all the help!
To Exhaust tips keep coming loose
