Gymkhana springs
Old Apr 5, 2004 | 06:12 AM
Vesa's Avatar
Vesa
Default Gymkhana springs
The front 550lb springs lower the front around 1". How it is in the rear with stock 7-leaf spring - does that also lover the rear around 1 "??? ...or will the car look like nose down and bottom up :cheers:
Old Apr 5, 2004 | 06:14 AM
Vesa's Avatar
Vesa
Default Re: Gymkhana springs (Vesa)
...and more specifically if the 7-leaf will lower 1 inch with stock bolts...
Old Apr 5, 2004 | 03:47 PM
NHvette's Avatar
NHvette
It shouldn't, but with the variability of today's aftermarket parts, it might.
Be prepared to make slight adjustments with any new rear spring.
:seeya
Old Apr 6, 2004 | 01:30 AM
Vesa's Avatar
Vesa
Default Re: Gymkhana springs (NHvette)
Thanks NH. From other source I heard that 7-leaf with same bolts might even raise the rear slightly. :smash: So definitely seems like 1" or a bit more longer bolts are needed... :steering:
To Gymkhana springs
