Sharp tapping from the engine..
Old Apr 24, 2004 | 09:27 AM
comp's Avatar
comp
Default Re: Sharp tapping from the engine.. (wackedvette)
re-check latest work...... most of the time thats where a problem is :thumbs:
Old Apr 26, 2004 | 10:43 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Default Re: Sharp tapping from the engine.. (Markm10431)
Beware...one that almost got me; thought I had a major problem. A sharp tapping which went from the right side of the engine all the way down to the oil pan. It ended up being a losse hose on the vacuum canister mounted over the valve cover on the right side of the engine. It cost me about .20 to fix.
Old May 7, 2004 | 07:04 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: Sharp tapping from the engine.. (gliot1)
now that could very well be.. I'm seeing a LOT of vaccuum problems
