There is no negative performance effects from the dual snorkel air cleaner as compared to the open element LT-1 style, unless you are running in excess of 6000 rpm for an extended period of time. Demand of CFM of air flow through the carb would be restricted if the opening of the snorkels was less than the total opening of the carb primary and secondary throttle plates. Measure the square inches of the snorkel openings, then the square inches of the Qjet or Holley butterflies. Then realize how often or the length of time that you drive your car with both primaries and secondaries wide open.
The snorkels do create turbulence in the air cleaner at high flow rates (WOT at high RPM) but is reduced by the restriction of flow through the cleaner element. The turbulence was eliminated with the open element that was stock in the HP engines, designed to red line at 7K.
Isn't engineering fun?
Red Sting, you have your instant messaging turned off so I could not respond to you IM. As soon as I responded (tried to) to your IM your info dissapeared into cyber space.
Please re set your features to permit instant messaging and try again ....
You could run flexable air ducting from the front of the engine compartment to both snorkles, or you could install an open element and let your enginge ingest hot air. Cold air is a proven power maker :yesnod:
