outer door handle rep or gm?
Old Apr 16, 2004 | 01:26 AM
MCMLXIX's Avatar
MCMLXIX
Default outer door handle rep or gm?
I purchased a reproduction outer left door handle and it has a huge gap between the handle and the housing. Does not match the original right handle at all. Does the GM handle have the same gap as the old handle? Before I send it back and get the GM one I want to know if it will match.
Old Apr 16, 2004 | 04:33 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: outer door handle rep or gm? (MCMLXIX)
The GM handles are better/higher quality than the repro's. Can't envision what gap you're speaking of, as all of the repro and original handles I've seen have the "flapper" fit nicely within the housing. The repro's have a poorer quality chrome, and a different hinge design.
I'd go with the GM handles, as replacing door handles is a miserable little job, and I'd rather do it once and not worry about it. :) Chuck
Pauld's Avatar
Pauld
Default Re: outer door handle rep or gm? (Chuck Gongloff)
:iagree:
Old Apr 16, 2004 | 06:14 AM
MCMLXIX's Avatar
MCMLXIX
The repro handle I got from zip has clearance for the flapper on the window side of almost 1/4 inch, the originale handle has about 1/16 inch clearance. Does the GM handle replacement have a small gap from the flapper to the housing like the original? The chrome on the repro is fine. I just dont like the uneven gap from the moveable handle to the housing it sits in. Does the GM replacement handle have an even gap all the way around the moveable handle to the frame surounding it, like the originale handle? Or should I find a used handle to match the one on the right door?
Old Apr 16, 2004 | 07:05 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I've heard the GM replacements are also "imported" now, my advice is buy one and return it if you are not satisfied.
Old Apr 16, 2004 | 07:11 AM
markdtn's Avatar
markdtn
Default Re: outer door handle rep or gm? (Pauld)
:iagree:
:iagree:
Old Apr 16, 2004 | 08:16 AM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
I replaced my door handles with "Trim Parts" brand from the Last Detial in Atlanta. Good fit, good chrome....an authorized GM restoation parts company :cheers:
Old Apr 16, 2004 | 09:30 AM
3joh's Avatar
3joh
I ordered the imported aftermarket handles, opened the box and sent them right back.
Not only was there an excessive gap between the flapper and housing, the corner radii of the flapper was squared off and didn't flow with the housing profile..............junk!
I have an original from my '69 chrome is not bad...no pitting....free to good home.
Jeff
[Modified by 3joh, 2:30 PM 4/16/2004]
Old Apr 16, 2004 | 09:32 AM
Fevre's Avatar
Fevre
Default Re: outer door handle rep or gm? (3joh)
I ordered the aftermarket handles, opened the box and sent them right back.
Jeff
Guess mine must be aftermarket since they have that mismatched look also. They are hard to pushdown at times and the spring just went on the drivers side. Sounds like it is time to get some real ones. :rolleyes:
Old Apr 16, 2004 | 11:34 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: outer door handle rep or gm? (Fevre)
I also bought GM replacements from The Last Detail. I wanted to avoid the import issues so I did not even consider the imports.
Old Apr 16, 2004 | 11:45 AM
Stewart's74's Avatar
Stewart's74
:iagree: I just did an adjustment on my Passenger door handle. Several skinned knuckles later the job was complete. Do it once and do it right.
Old Apr 16, 2004 | 12:02 PM
1974ta's Avatar
1974ta
Default Re: outer door handle rep or gm? (Stewart's74)
Always spend the extra and do it once!
The repro parts are never, never the same fit and/or quality as the originals.
Will they work? Maybe. Why take the chance. I am on my second GM restoration and frankly do not have a lot of good things to say about the most repro parts.
My first was a 68 GTO ragtop and now I am on to a 70 Roadster.
Have fun!!
Old Apr 16, 2004 | 09:37 PM
MCMLXIX's Avatar
MCMLXIX
Jeff,
I would be interested in your handle. Is it left or right side? I need left but maybe I could use use the springs to repair mine. A used handle would match the other door better. A new shiny handle on one door and a 35 year old one on the other door just looks wrong. I would gladly pay for shipping, handling, time and trouble. I promise my door is a good home for your handle it will recieve good care and be taken out daily for exersize.
Old Apr 18, 2004 | 06:51 AM
m1k3's Avatar
m1k3
I'm actually taking on this project myself right now.... Can anyone offer some advice on how to get the old handles off once the door panel is removed?
-Mike
To outer door handle rep or gm?
