71 power window problem
Old Apr 16, 2004 | 09:53 PM
Viking427's Avatar
Viking427
Default 71 power window problem
Got a problem with a pwr window on a 71; Drivers side doesn't want to go back up (new motors/regs/switches). Brown wire at motors plug gets 12vdc one way, but Blue wire gets nothing the other. No wiring diagram, but its my belief the relay, breaker and all grounds must be good since all other functions work ok. So I'm thinking a broken wire either before the switch or b/n switch and motor, anyones input appreciated.
Old Apr 17, 2004 | 08:48 AM
Wrecked82's Avatar
Wrecked82
Default Re: 71 power window problem (Viking427)
Work back. Have you checked the blue wire at the switch? Then check the wire feeding the blue wire before the switch by jumping across the power that the blue wire feed.
