Sanden 508 AC Compressor
Old Apr 22, 2004 | 10:14 AM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Sanden 508 AC Compressor
I have had bad luck with the Rebuilt Chrome AC Compressors. I have had two that leaked at the front seal and now have a third one in the garage and will try to install it this weekend. After two failures my hopes are not high.
Does anyone have the Sanden 508 or anyother type installed on a C3? Specifically, what were the installation obstacles?
Old Apr 22, 2004 | 10:20 AM
groovyjay's Avatar
groovyjay
Default Re: Sanden 508 AC Compressor (OHSIXX)
I'm using the 508 on my BB, no problems with the installation:
Old Apr 22, 2004 | 10:29 AM
OHSIXX's Avatar
OHSIXX
Default Re: Sanden 508 AC Compressor (groovyjay)
Nice pic, but that does not look anything like mine. Just guessing I will need some fabricated brackets, but not sure what else. I am curious if there is something else that will just bolt on or require minimum fabrication?
Old Apr 22, 2004 | 10:37 AM
Tex71BB's Avatar
Tex71BB
There are several companies that supply the brackets - this one seems reasonable: http://www.alangrovecomponents.com/Catalog.htm
Other than brackets, I think all you need are some custom-fabricated hoses that most any good A/C shop should be able to do.
Old Apr 22, 2004 | 11:00 AM
OHSIXX's Avatar
OHSIXX
Default Re: Sanden 508 AC Compressor (Tex71BB)
Terrific! Exactly what I was looking to find. Now I have a good backup plan in case the third one leaks. Thanks again. Mark
Old Apr 22, 2004 | 06:36 PM
mrvette's Avatar
mrvette
OH6, go to Custom Auto Air on Phillips and University....Bowden.....they do custom hoses, took good care of my vette....I have an '88 vette compressor and serp drive on my engine....I recommend the entire changeover....
but if you still have the old mechanical fan, maybe...well not sure if you can get reverse rotation fans or not.....
but then again...go electric fan like I did....
nose, camel, tent, sand, desert, ......
GENE
Old Apr 22, 2004 | 07:11 PM
OHSIXX's Avatar
OHSIXX
Default Re: Sanden 508 AC Compressor (mrvette)
Hey Gene: Thanks. I will go by there next week.
To Sanden 508 AC Compressor
