1972 CARPET HELP
Old Apr 22, 2004 | 10:39 AM
A72COUPEDT's Avatar
A72COUPEDT
Default 1972 CARPET HELP
HELP..GETTING READY TO INSTALL MY NEW CARPET IN MY '72 COUPE. IS THERE A"CORRECT" WAY TO INSTALL THIS NEW CARPET? FOR INSTANCE FRONT FIRST, THEN THE BULKHEAD/REAR CARGO AREA? DOES THE NCRS CHECK UNDER THE CARPETING? INSULATION ALREADY IN PLACE. :conehead
Old Apr 23, 2004 | 07:34 PM
sjr1971's Avatar
sjr1971
Default Re: 1972 CARPET HELP (A72COUPEDT)
I redid mine this winter. NCRS? Don't know them. My stepson said " It's 33 years old but it looks new." I can live with that. I put the wheelwells in 1st; then the back deck[leaving overhang to fit/trim the bat/jack/glove boxes] then both driver/pass side. Last the bulkhead behind the seats. You'll see that you can't cut stitched seams[ backdeck & rear bulkhead] center the best you can. Align the lower bulkhead seams to their lower points on both sides; glue[3M]; tuck into the grooves at the door jambs; over the top of the bulkhead and under the front of your box frame. Good luck '72
Old Apr 23, 2004 | 08:28 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: 1972 CARPET HELP (sjr1971)
Not to many NCRS types here; but I bet they look under your carpet and check out the air quality in your tires as well. BTW, nothing like new carpet! :jester
Old Apr 23, 2004 | 08:59 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Default Re: 1972 CARPET HELP (OHSIXX)
If anybody is interested, I bought some trunk carpet by the yard at a local auto shop,, its affordable, 35$ for the back and behind the seats. and its looks realy good!!!!!,, very easy to work with
Old Apr 24, 2004 | 09:43 AM
A72COUPEDT's Avatar
A72COUPEDT
Thanks sjr...any and all help is just what I needed. Just tryin to do it right the first time. Nothing like experience. :banghead:
Old Apr 24, 2004 | 09:45 AM
A72COUPEDT's Avatar
A72COUPEDT
Hey..when they test that air, what do they look for?? :lol:
To 1972 CARPET HELP
