Door stuck in lock
Old Apr 23, 2004 | 12:55 AM
Pettee17's Avatar
Pettee17
Default Door stuck in lock
Hi everyone, I did a search and couldnt find what i was looking for, so i figured i would post up on here. I just purchased a 74 Vert, and the passenger door is stuck in lock. And closed...you see my problem here. I cant get it open. I was wondering if anyone has had this problem before? and if so, how did you fix it? Thanks
Old Apr 23, 2004 | 01:02 AM
75_STINGRAY's Avatar
75_STINGRAY
Default Re: Door stuck in lock (Pettee17)
Hi. I've got a 75 with the same problem, only it's the driver side. It's very anoying. I have to get in trough the pass side. But I havn't got it fixed yet and I don't really know whats wrong with it. :banghead: So anybody who could help, please do...
Old Apr 23, 2004 | 03:51 AM
mapman's Avatar
mapman
Remove the door panel of the DRIVER'S door. Now study the lock mechanism to see how the lock works. Fashion a wire (heavy duty coat hanger) with a small hook and practice "opening" the driver's side lock by going down through the window opening on the door.
With the knowledge gained, you can now open the passenger's side door. Worked for me.
Changing parts in the door can be a PITA, my door handles were worn and had to be replaced. It helps if you can get someone with small hands (wife/girlfriend/etc) to remove clips or start nuts on bolts.
[Modified by mapman, 2:53 AM 4/23/2004]
Old Apr 23, 2004 | 08:07 AM
desi's Avatar
desi
IM MotorHead. I think he had similar problem on his 80 last year.
Old Apr 23, 2004 | 09:44 AM
nicecurves79's Avatar
nicecurves79
Default Re: Door stuck in lock (mapman)
:withstupid: mine did the same thing. just take it apart until you find something wrong. mine had a bind in the linkage. oh, and take it from me its not good when you go on a date and cant get the door open. :D
Old Apr 23, 2004 | 09:48 AM
Pettee17's Avatar
Pettee17
Great advice. Thanks! looks like i have a sunday project now :D
Old Apr 24, 2004 | 08:47 PM
vette90189's Avatar
vette90189
Does anyone have a picture they could email me b/c I have messed with my drivers side door that has been getting stuck in lock for a while with no fix yet but I think my problem may be in a spring that is in the door so i need pics to see if that is my problem
Old Apr 25, 2004 | 01:05 AM
outrunm's Avatar
outrunm
St. Jude Donor '06
Default Re: Door stuck in lock (vette90189)
I farted around with mine for 2 weeks til I took it to a locksmith, It will cost you 80 to 100 beans, but just tell them you have a case of "Corvette Door". If they are competent, they will know what the problem is and the remedy. I hate to spend money on shizitt that I should be able to fix myself, but some things can be messed up more by Bubba with a coat hanger trying to figure out how something works.
Old Apr 25, 2004 | 03:56 AM
Pettee17's Avatar
Pettee17
Default Re: Door stuck in lock (outrunm)
Hey Outrunm, thats what im going to do, i played with it tonight, and just gave up, just gonna bring it somewhere and have them do it. Itll cost money, but save me frustration :smash:
Old Apr 25, 2004 | 11:06 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine is still locked I also have a plastic insert that protects the locking mechanism from coat hangers, slim jims etc.
I figure I have to take off the door panel, only problem here is you can't get at one of the screws in the top corner so I think you have to take the trim off that goes up to the t-tops and across. Haven't got around to it yet. :D
Old Apr 25, 2004 | 07:40 PM
hunt4cleanair's Avatar
hunt4cleanair
I wrote an article for NCRS Corvette Restore that was published with photos a few years back. It's tedious work but can be accomplished with patience... My procedure was to use a large blade screw driver and "trip" the secondary latch through the window opening and pushing the black plastic protector aside. The reference above suggests the basic procedure.
If I HAD A CORVETTE FORUM WEBSITE PAGE...I COULD POST PHoTOS. But since joining such a service has failed to come forth so those who may benefit from such posting...are unable to!
Old Apr 25, 2004 | 08:54 PM
Pettee17's Avatar
Pettee17
Default Re: Door stuck in lock (hunt4cleanair)
Hey everyone, I got it fixed today. Had to go in through the top of the door and open it with a screwdriver, and then pulled off the door panel once it was open. To make my life easy, i just put the door in unlock, and pulled all the rods out, so it wont lock. The top wont ever be up, so i see no reason to lock the door again anyway.
Old Apr 26, 2004 | 10:31 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
The mecahnisms really isn't that hard to deal with once you take off the door panel. More than likely one of the rods just needs its length adjust. All of the rods can be turned (they are threaded) to adjust the length whihc affects the mechanism. It's pretty basic.
Old Apr 26, 2004 | 12:42 PM
MotorHead's Avatar
MotorHead
Default Re: Door stuck in lock (gliot1)
Where can you get those little weird tab/tangs that hold the rods in place at the ends ?
Old Apr 26, 2004 | 01:16 PM
72GACRZR's Avatar
72GACRZR
Default Re: Door stuck in lock (MotorHead)
Here's one place.
http://www.volvette.com/Merchant2/merchant.mv?
Then do a search on "door lock rod clips"
Well I had them , but now it won't go to the same place, sorry. Guess you will have to go thru the door part page by page.
[Modified by 72GACRZR, 1:19 PM 4/26/2004]
[Modified by 72GACRZR, 1:25 PM 4/26/2004]
To Door stuck in lock
