I just took the 81 out and brought it right back! There is a vibration, feels like its coming from the back. You can feel it for seconds and then its gone for about the same amount of time, this cycle just keeps going and going. The tires are new and balanced( weights are still there, I checked) Anyone have any ideas befoe I go out there tomorrow and start pulling things apart? Thanks for any tips.
:mad
do a search for vibration. you will find many results pointing to things to check. i had a very similar vibration to yours. turned out the bell housing bolts were loose on the drivers side. other good places to look...tranny and engine mounts...u-joints...try rotating the tires. it can seem endless at times. :banghead: good luck :cheers:
