Lift off
Old Apr 24, 2004 | 09:43 PM
stpman's Avatar
stpman
Default Lift off
After a great cruise to meet with the shark pack guys I got down to work and got the 73 body lifted off of it's frame.
http://www3.sympatico.ca/ncardwell/73_vette/Lift_1.jpg
http://www3.sympatico.ca/ncardwell/73_vette/Lift_2.jpg
http://www3.sympatico.ca/ncardwell/73_vette/Lift_3.jpg
Some pictures of the frame, what I was expecting but hoping I wouldn't find
http://www3.sympatico.ca/ncardwell/73_vette/Frame_1.jpg
http://www3.sympatico.ca/ncardwell/73_vette/Frame_2.jpg
http://www3.sympatico.ca/ncardwell/73_vette/Frame_3.jpg
http://www3.sympatico.ca/ncardwell/73_vette/Frame_4.jpg
http://www3.sympatico.ca/ncardwell/73_vette/Frame_5.jpg
http://www3.sympatico.ca/ncardwell/73_vette/Frame_6.jpg
http://www3.sympatico.ca/ncardwell/7...Finished_1.jpg
I would like to thank 75Rag for inviting me to ride shotgun in the morning and coming out to help with the body lift :thumbs:
Steve :steering:
Old Apr 24, 2004 | 09:49 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Lift off (stpman)
Looks like you have your work cut out for you. Make sure to keep us posted on the progress you are making. It is good to see people taking on these kinds of projects and watching them to the end.
Old Apr 24, 2004 | 10:17 PM
carl a's Avatar
carl a
Default Re: Lift off (Eddie 70)
DO YOU PLAN ON REPARING THAT FRAME? MINE WASNT THAT BAD AND I CHOSE TO GET A NEW ONE- MAKE SURE YOU COAT THE INSIDE OF THE FRAME TO PROTECT IT FROM RUSTING FROM THE INSIDE OUT( I USED Z BART INSIDE AND POR-15 OUTSIDE-------CARL A ----------
Old Apr 24, 2004 | 10:38 PM
stpman's Avatar
stpman
Default Re: Lift off (carl a)
Carl
no plans to repair that frame, in fact it went back into the garage intwo sections. cut at the kick ups at the back and just in front of the #1 body mount. The only part salvagable from section in the middle was the Trans Xmember.
Steve :steering:
Old Apr 24, 2004 | 10:39 PM
NHvette's Avatar
NHvette
Bummer on that frame ... .it could be fixed, but that's a lot of work.
What did you do - cut the frame into pieces ?
:seeya
Old Apr 24, 2004 | 10:44 PM
stpman's Avatar
stpman
Default Re: Lift off (NHvette)
Dave the frame was cut in three sections, you can see the front and rear section in picture Frame_6. It actually only took about 5 minutes to cut the back off and another 5 for the front. when we looked at how bad it actually was I deceided to use tyhe frame frome my 74 parts car instead (way too much rot on the 73)
Steve :steering:
[Modified by stpman, 10:45 PM 4/24/2004]
Old Apr 25, 2004 | 12:13 AM
R 73 454's Avatar
R 73 454
Wow, after viewing those photos, I hope I don't have nightmares tonight! I probed a hole in my '94 Escort wagon's rocker panel, upon closer examination the metal was all rotted, inside the rocker channels was at least 15 pounds of salt and sand!!!!!!!! :eek: Rust sucks, or at least road salt does! :nopity :U
Old Apr 25, 2004 | 03:17 AM
RHD '68 L89's Avatar
RHD '68 L89
What was holding that poor thing together?
Did you drive it like that? How did it feel? :eek:
Old Apr 25, 2004 | 03:51 AM
stingraymaniac's Avatar
stingraymaniac
Default Re: Lift off (RHD '68 L89)
oooh that poor car!!:eek:
nice too see it beeing restored,good luck with the resto!
Old Apr 25, 2004 | 05:57 AM
redwingvette's Avatar
redwingvette
Default Re: Lift off (stingraymaniac)
Thats nasty! Looks like the bird cage/rocker channels are not to good either? Whats the plan?
Good luck
Old Apr 25, 2004 | 09:13 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Good luck with your project... :thumbs:
Old Apr 25, 2004 | 09:25 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Lift off (AGVI)
After seeing those I ran outside and looked under my car. Whew still lookin good
Old Apr 25, 2004 | 02:33 PM
stpman's Avatar
stpman
RHD'68 L89
Not sure what was holding it together, when I was cutting on one side of the fraame rust was falling of the other side. No I didn't drive it I bought it knowing it had a bad frame.
Redwingvette
The rockers are bad and will be replaced, will be travelling through your area next month and stopping to pick up the parts I need.
The plan is to put this car together using the frame from a 74 I have
Steve :steering:
Old Apr 25, 2004 | 02:57 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Good luck bro. :thumbs:
Old Apr 25, 2004 | 08:14 PM
GTR1999's Avatar
GTR1999
Default Re: Lift off (wackedvette)
Nice pictures,good luck with the resto. I'm sure it will come out great.
How high was the hoist boom and di you have any issues removing the body using it?
Thanks,
Gary
Old Apr 25, 2004 | 08:18 PM
MikeC's Avatar
MikeC
Default Re: Lift off (gtr1999)
OUChY Steve!
that frame makes mine look like it was worth saving!
Good Luck, your fun is about to begin!
Old Apr 25, 2004 | 10:29 PM
stpman's Avatar
stpman
Default Re: Lift off (MikeC)
Gary
The boom ended up being 10' from the floor (could have used about 2" more)
MikeC
the fun will begin when it starts going back together
Steve :steering:
To Lift off
Old Apr 26, 2004 | 09:59 AM
johns73's Avatar
johns73
I just did the same thing this past winter. I went from a relly bad 73 frame to a 76 frame and replaced the rocker channels. Take your time and mark everything you take off. I had mine aligned on thursday and it rides like a new car now. :party: Good Luck John
Old Apr 26, 2004 | 11:03 AM
75Rag's Avatar
75Rag
Steve :steering:
No problem Steve ..... you've ALWAYS been there to help me out, it's the least I can do. Anytime I can help, I'm still in debt to you!
Old Apr 26, 2004 | 11:05 AM
groovyjay's Avatar
groovyjay
Good luck it will be a long but fun project! :yesnod: :cheers:
