Pertronix 2 revisited
Old Apr 27, 2004 | 12:59 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Pertronix 2 revisited
It's been five months with the Pertronix-2 igntion system and although it's got a bad wrap by a few froum members it really does what it says it's saupposed to.
If you actually follow the instructions it take 30 moinutes including pulling the distributer only if it has end play (brass washer/ shims) if no end play it could be set up in 15 minutes.
I stupidly bent mine when I installed a new vacuum cannister which had nothing to do with the P-2 but my own stupidity. I straightened the frame out and after 2000 miles it has no wear. Hell aside from my goof up it shows no wear. Before it took some pedal to start the car now I just reach into the interior and fires right up. Anyway just checked it out this morning and as good as ever. I expect this unit to outlast the Vette.
Old Apr 27, 2004 | 04:10 PM
LemansBlue68's Avatar
LemansBlue68
Default Re: Pertronix 2 revisited (Cali,68,L-79)
I've been back and forth about the P2 or the Breakerless SE system. Breakerless SE is a bit more money but I don't know if there is any more advantage to it other than 1 wire rather than 2. I keep hoping the price will come down.
Old Apr 27, 2004 | 04:56 PM
Cali,68,L-79
Default Re: Pertronix 2 revisited (LemansBlue68)
$108.00 at Summit is cheap.
Old Apr 27, 2004 | 08:30 PM
'69CoupeDude's Avatar
'69CoupeDude
$101.45 delivered to your door at vintageperformance.com.
Old Apr 28, 2004 | 12:44 AM
Solid LT1's Avatar
Solid LT1
Default Re: Pertronix 2 revisited ('69CoupeDude)
I've been using the product for almost 20 years now with no complaints. You should always check the grounding wire from the advance plate to the distributor body to insure it has not failed in a Pertronix system, if the wire is broken, there can be an intermittant miss of the ignition system.
Old Apr 28, 2004 | 02:16 AM
AV8RSVT's Avatar
AV8RSVT
Default Re: Pertronix 2 revisited (Solid LT1)
I also decided on the Breakerles SE ignition. Very easy install No wires to run for A 12V source. It runs very well! :D
Old Apr 28, 2004 | 04:15 AM
DMONSVETTE's Avatar
DMONSVETTE
:cheers: :seeya
Old Apr 28, 2004 | 09:15 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: Pertronix 2 revisited (AV8RSVT)
I also decided on the Breakerless SE ignition. Very easy install No wires to run for A 12V source. It runs very well! :D
I installed the same Breakerless SE system. Easy to do, and you can't tell it's there.
Old May 3, 2004 | 08:16 PM
Easy Rider's Avatar
Easy Rider
I've been running with Pertronix II since my original Pertronix failed over 2 years ago. I have not had a single problem with the new unit.
Old May 4, 2004 | 08:57 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Mines the same.
One turn of the key and it starts up. Once I set the timing I don't tinker with the distributor. Nothing like a little bit of reliability....
Old May 4, 2004 | 09:41 AM
kenko74's Avatar
kenko74
I installed my "Ignitor" (pre-ignitor II) 4 1/2 years (12,000 mi) ago, and have had no problems. I haven't once missed the good old days of adjusting the points! :smash:
Old May 4, 2004 | 12:01 PM
Gage's Avatar
Gage
I thought the only benefit I would get from the PII was quicker starts and no messing with points, but the damn thing definitely had more HP. Prior to installing, car idled at 750 rpm, after install, idling at 1100 with same throttle position. Tells you how much more efficient car runs with it.
Old May 4, 2004 | 12:08 PM
Leo001's Avatar
Leo001
I just installed the breakerledd SE (replaced a petronix) I never had a problem with the Petronix, but I just liked the mechanics of the brealerless SE system more. It runs much smoother (but the whole distrubitor was rebuilt by Lars) so I dont attribute the better proformsaance to either unit but to the fact there is a new distrib. in the engine. I think either will be fine.
Leo
To Pertronix 2 revisited
