Brake Bleedin question
Old Apr 27, 2004 | 01:45 PM
Garys '68's Avatar
Garys '68
Default Brake Bleeding question
After replacing my rear calipers and bleeding all my brakes (in the correct order), I discovered I needed a new rear brake line. While replacing the rear brake lines, the rear master cylinder drained, the front stayed full. So I rebled the rears only.
Do I need to rebleed the fronts? Is there anyway in the master cyliner or proportioning valve that air can transfer from the rear brakes to the front?
Gary
[Modified by Garys '68, 6:46 PM 4/27/2004]
Old Apr 27, 2004 | 02:01 PM
Z-man's Avatar
Z-man
Default Re: Brake Bleeding question (Garys '68)
I would bleed the rears then check pedal firmness. If the brake pedal feels solid (and if the brake warning light does not come on) then you should be good to go. Unless there is a leak, there shouldn't be any transfer from front to rear.
Good luck
Old Apr 27, 2004 | 02:02 PM
mvftw's Avatar
mvftw
If after you bleed the rears, remember drivers inner first, and the pedel is hard your done. A good pedel is your test, if it's still good after a short drive, your done. But it is a good to bleed the system anyway...
Old Apr 27, 2004 | 02:17 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
I would say fronts don't need to be bled. Front and back are supposed to be two independent systems, key word = supposed. Couldn't hurt to do it again if you have the time and extra brake fluid.
Old Apr 27, 2004 | 03:52 PM
LemansBlue68's Avatar
LemansBlue68
I'd bleed both front and rear just to replace the old fluid. It absorbs water over time and will eventually rot your lines and corrode your M/C if allowed to get too old. You'll be surprized how funky the old fluid will look if it's more than a couple of years old.
Old Apr 28, 2004 | 09:15 AM
Garys '68's Avatar
Garys '68
Default Re: Brake Bleeding question (LemansBlue68)
I had already replaced all the front fluid after replacing rear calipers and rear fluid. I then found the bad line in back (bad timing). Anyway, the pedal is much harder and it seems to stop OK. Looks like I'll be OK as is.
Gary
To Brake Bleedin question
